Technical Tire Wobble
Discussion in 'The Hokey Ass Message Board' started by Jeffrey A, Oct 4, 2017.
  1. Jeffrey A
    Jeffrey A
    I've got a 48 Ford rat rod with a ford straight axle suicide front end setup sometime it front tires get into a horrible tire wobble you think it's gonna tear the front end off the truck it's so bad any ideas on how to correct or fix the problem
    els and chryslerfan55 like this.
  2. slim39
    slim39
    from pa
    Check the toe in
    els likes this.
  3. tfeverfred
    tfeverfred
    Try the SEARCH feature.
    els likes this.
  4. ROADSTER1927
    ROADSTER1927
    Check all of the front end for loose and worn parts. Then have it aligned at a good shop. Have the wheel and tires spin checked and balanced.King pin and tie rod slop and tire pressure ar very important. Good luck, Gary
    els likes this.
  5. check out death wobble in the search lots on it
    els likes this.
  6. lothiandon1940
    lothiandon1940
    .........................................Really!:rolleyes:
  7. pat59
    pat59
    Hot Rod, say, Hot Rod! :)
    els and clunker like this.
  8. Jeffrey A
    Jeffrey A
    Thanks for all the info all the parts are new so I'll start with the toe in would installing a steering damper help also?
    els and Mark Roby like this.
  9. Dreddybear
    Dreddybear
    Likely yes, though often is a band-aid for poor steering design (e.g. tie rod in front, etc..). You're inviting ridicule a bit with the "Rat Rod" term.. it doesn't go over well around here. Don't sweat it if you get some hazing, you're in the right place. The best way to get some advise is to post some pics of your setup. Roasdster1927 gave some good tips. :) And yes toe should be around 1/8"..
    els likes this.
  10. bobss396
    bobss396
    Lose the RR word, not at all accepted here.
    els likes this.
  11. Jeffrey A
    Jeffrey A
    els likes this.
  12. Jeffrey A
    Jeffrey A
    Sorry o_O new at this thanks for the tips
    els likes this.
  13. Jalopy Joker
    Jalopy Joker
    els likes this.
  14. lothianwilly71
    lothianwilly71
    Try a front end shop that works on older cars...
    lothiandon1940 likes this.
  15. bobss396
    bobss396
    Or the oldest truck shop in town that does alignments.
  16. Jeffrey A
    Jeffrey A
    Tried yalls advise and the toe in helped so much now my HOT ROD drives so much better . I did it myself using the string method and amazingly it worked perfect Thanks again for the help
