Hot Rods Tired of homogenized hotrods
Discussion in 'The Hokey Ass Message Board' started by onekoolkat1950, Dec 24, 2015.
  1. A Boner
    A Boner
  2. Those hoodlums, as you put it, are The Beach Boys.
    jankeh, Stogy and Six Ball like this.
  3. And umm, just where do youse guys think you’re going?
  4. Stogy and tb33anda3rd like this.
  5. lippy
    lippy
    from Ks
    I sure wouldn't want to waste that much time on that.
  6. Stogy
    Stogy
    That sure wasn't your average soap box derby special that for sure...
  7. Stogy
    Stogy
    Credit to Photographer, Owner
  8. Stogy
    Stogy
    Sancho, patmanta, 63fdsnr and 7 others like this.
  9. Jalopy Joker
    Jalopy Joker
  10. Stogy
    Stogy
    Shrapnel, Sancho, patmanta and 10 others like this.
  11. Stogy
    Stogy
    :rolleyes:...A rare Sighting of a Model A rad and shell on a Model A Hotrod...:D
    Real Nice Hotrod indeed...
    Interesting too is the mix of Rims...
    That Ole Pickup looks mighty nice in the background there as well...
  12. Gotta be photoshoped. It sits way too low to be “traditional”
    Sancho, Jim Bouchard, hfh and 2 others like this.
  13. Six Ball
    Six Ball
    from Nevada
    A guy I knew in the early '60s had a '36 about that low. Part of his trick was to remove the springs and U-bolt both axles to the frame. He didn't drive it much.:eek:
  14. Stogy
    Stogy
    :rolleyes:...This is a Hambers and is up for grabs I believe...
  15. Stogy
    Stogy
    You highlight a modeling option that happened in many a dimly lit shop with as you allude the forthcoming lowering blocks...I sometimes am unsure of digital authenticity of images but I've always enjoyed the look of that modded or not...so many things in Custom cross the Hotrod spectrum...I guess many methods were tried with solid mount notifying builder a C-notch or Z or...:eek:...is part of the deal...
    Six Ball and chryslerfan55 like this.
  16. BrandonB
    BrandonB
    from nor cal
    Not mine but a friends shortened 31 Ford roadster body sitting on a 1937 Willy frame running a Latham supercharged Pontiac flathead straight 8 with an upgraded 37 Willys ******, , and 201 QC rear end. (See Post 5691)
    IMG_8719.JPG IMG_8720.JPG IMG_8721.JPG IMG_8722.JPG IMG_8723.JPG IMG_8725.JPG IMG_8726.JPG
  17. BrandonB
    BrandonB
    from nor cal
  18. Stogy
    Stogy
    :rolleyes:...definately an unusual wheelbase, tailights and pretty heavy on the channel...
  19. Stogy
    Stogy
    Man that's fits the ambience of this Thread to a 'T'...I'd like to know more of it's History...it probably goes right back to postwar in Hotrod...thanks for sharing it Brandon...;)
  20. Essex_29
    Essex_29
    from Finland
    1928 Es*** Super Six, built 2003-2008. Four doos six light bodystyle made two door coach, by shortening the body 8" and welding rear doors shut. Chopped 2", angle channelled 2" in the rear, 5" in the front.Original front axle with '68 Satellite 11" brake drums. Seventies Volare 7-1/4" rear end. Rover 3500 engine with Buick 215 valve covers, Offenhauser intake and a Holley390, air cleaner made from two 1938 Chrysler head light buckets. Tank in the front contains the battery. Simple and loads of fun.
  21. BrandonB
    BrandonB
    from nor cal
    You're right about that, Stogy. This car was built to run at Muroc back in the mid 40's. It was called "The Lil Singer Sewing Machine" at that time it was painted white. It had the Willys flathead four cylinder with an aluminum Hickey head running a Graham supercharger. It was around 1946-48 that it held the record in it's cl*** at Muroc at 125 MPH and change. Back in the 70's that car was restored and then it just sat. It was advertised in the back of Hot Rod magazine in the late 70's where my buddy Mel saw the ad and drove down to LA and bought the car. I've talked about the car on here before and some of the older guys on here remember the car. I think one guy said he had a magazine or saw it in an old Hot Rod magazine. Mel has all the original parts to put it back the way it was but I think he did a really fantastic job on "upgrading" it.
  22. Stogy
    Stogy
    Do you have any pics of it at Muroc Brandon?...it certainly must have captured the Eyes of Photographers with that kind of record making...that steering wheel is Aviation sourced and not uncommon with wartime hardware nearly being given away...You certainly have shared enough to do some serious searching...It looks familiar to me...perhaps I've seen your previous sharing of this survivor...
  23. BrandonB
    BrandonB
    from nor cal
    ^^^^No, no help there Stogy.^^^^ I think the guy that owns the car might have the magazine it was in.
    Stogy likes this.
  24. studebakerjoe
    studebakerjoe
    @Stogy I believe it's been in a few magazines. I know I've seen it. Can't recall exactly where, but if I come across it Ill let you know.
    chryslerfan55, BrandonB and Stogy like this.
  25. Stogy
    Stogy
    https://www.jalopyjournal.com/forum/threads/1931-ford-roadster-w-pontiac-straight-8.835797/
    :rolleyes:...Well Brandon...snooping around proved a bit fruitless but I did find a Thread you did on it and in true Hamb Fashion I share that link above as Hambers like yourself post awesome History and it always flows better when you have multiple dots to connect content shared...Mel is a natural for exotic experimentation...;)
  26. Stogy
    Stogy
    :rolleyes:...Another not so average Deuce 5w turned 3, running a Flathead Caddy I believe...
    Sancho, chryslerfan55, hfh and 2 others like this.
  27. Stogy
    Stogy
