gotta put the rad in front of the crossmember to get it down...gonna havh to make an oval lower pipe to clear,,
LOL... THATS THE VISION i HAVE WHEN i LOOK AT MINE is that 3'' chop??? I have to get the rad down some how.. and was not wanting to move the axel out farther...any way... I keep head scratching...I can't run the rad that high also looking for a model a windshield frame if some one has one...
The axle is usually set up to be just in front of the radiator, or you could run a shortened radiator/surround.
I'm thinking I wanna drop the rad down in front of the cross member so the grille looks longer??? wanna stay away from the T bucket look..... we'll see... also hoping that this year you won't be kicking me in the nuts every chance you get....So happy New Year to you...
As a rule I don't like the top of the rear tire taller than the deck lid, however this car NAILED IT. Thank you for posting the photos. Bob
I was going to give you a few links and suggest some hambers with cars similar to what you are asking about...... until I just read your reply. I'm sure you will sort it out yourself.
I say when the tires go up, the lid needs to come down.. also thinking i'm going with the square tire look instead of big and littles.. so top will be chopped a little
