Technical Tires/Wheels
Discussion in 'Traditional Hot Rods' started by 42flattman, Jul 1, 2020.
  1. 42flattman
    42flattman
    I have a '42 Ford Tudor Sedan that I am going to put aftermarket wheels (Wheel Vintiques 15" Gennies) and tires on....I was hoping to be able to fit a pair of Cooper 265/70R15 on the rear without needing to modify anything back there......looking for input before I buy the tires.
    Appreciate any thoughts or previous experience.
    Thanks
    John
  2. 42merc
    42merc
    How wide are your new wheels?
    I installed 15 X 7 Gennies with 235-75 x 15's on my '42 & things got pretty tight.
    Looked good tho.
    I have no experience with larger tire sizes.
    i.rant and lothiandon1940 like this.
  3. Hnstray
    Hnstray
    from Quincy, IL
    @42flattman
    265 mm sidewall cross section, converted to inches, is right at 10.5”. That is a lot of width to stuff into your Ford’s rear fender well. I had a ‘47 some years ago, with 235/70-15 tires and they filled the space nicely. ‘42 through ‘48 are, I believe, the same width axles and fenders.
    Nice looking Tudor.......
    Ray
    i.rant likes this.
  4. Nailhead Jason
    Nailhead Jason
    That’s aweful right to try to squeeze that in there. I would put the car in stands under the axle take the wheels off and start measuring to see what would fit. If you could get 265s in there with out cutting and moving the inner well I’d be shocked.
    a friend has 8.50 15 bias plys on his 46 and they are real tight and not near was wide as what your talking about.
  5. 19Fordy
    19Fordy
    Also make sure the rear tire sidewalls "clear" the spring hangars
    and inner fender panel when turning corners or when trunk is loaded.
    Hnstray and i.rant like this.
  6. i.rant
    i.rant
    LeatherLunger and Hnstray like this.
  7. vtwhead
    vtwhead
    John, back in the day (2007) at our store we would mount up test sizes for applications like yours to check fit with the customer. When we found the right size we would then sell them to the customer, balance them up and send him on the road. Surely there must be a store in your area that would help you out prior to buying the tires.??????
  8. 42flattman
    42flattman
    I was going to go with 8”....but looks like may have to scale back to what you used....sounds like you were about max’d out.
  9. 42flattman
    42flattman
    Ray, Thanks for your input...and the compliment ! Sounds like I will be dropping back to 235’s.
  10. 42flattman
    42flattman
  11. 42flattman
    42flattman
    Looks like some handy information....I will print this off tomorrow. Thank you !
  12. 42flattman
    42flattman
    I didnt think about someone doing that....but I will give my tire store a call and see if they will help.....Thanks so much for that idea
