1952-59 Ford Tires width
Discussion in 'Off Topic Hot Rods & Customs' started by BeerMoney, Sep 12, 2023.
  1. BeerMoney
    BeerMoney
    can i put 225-70-15 on my 55 ford customline
  2. evintho
    evintho
    I don't see why not. I currently have 215/70R-15's on my '54. Plenty of room.
  3. jimmy six
    jimmy six
    On the rear? I believe you can in a 6-7” wide rim but if it lowered you may have a problem getting it off. I used a 215-75-15 on a 6” rim on a non lowered 56 and the tire hits the body edge and brake drum if I try to remove one if the rear of car is picked up level. If I do one side at a time it’s easier and I carry 2 jacks in the trunk.
  4. Keep the wheel backspace up (4 to 4.5") and don't go wider than 7". I put 235/75-15 tires on a '56 I used to own on OEM 6" wheels and they s****ed lightly on both sides of the wheelwell....
  5. ajracing9
    ajracing9
    I just put on 235/70-15 the rear is tight. In mind there's a decent amount of space but you do have to play musical jack stands to get it on and off lol
  6. jimmy six
    jimmy six
    ^^^^^^ fun on the side of the road.
    I use a scissor under the spring clamp AND a stock bumper jack. It’s the only I can get a rear off.
    ajracing9 likes this.
  7. JeffB2
    JeffB2
    from Phoenix,AZ
    ajracing9 and nosford like this.
  8. jax59
    jax59
    from East Bay
    215/75/15 here IMG_2862.jpeg
    ajracing9 and down-the-road like this.
  9. bobss396
    bobss396
    I run 235/75-15 on the back and 215/75-15 on my front. The rears are tight to get on and off. The fronts will hit on the outer side on inclines, the disc brakes shoot the wheels out a tad.
  10. 55customlinecowboy
    55customlinecowboy
    I'm running a 235/70 r15 with out any issue on a stock wheel
  11. 55customlinecowboy
    55customlinecowboy
    I'm running a 235/70r15 on a stock wheel with no issues amd my car is lowered an inch in the rear.
