Technical Titanium exhaust wrap for wiring
Discussion in 'The Hokey Ass Message Board' started by Hotrodjohn71, Feb 6, 2023.
  1. Hotrodjohn71
    Hotrodjohn71
    My old Pontiac has a steel tube behind the driver's side head (between firewall and head) that (2) 12ga wires go through to the starter.
    The tube is intended to protect the wires from exhaust pipe and nanifold heat, but I've been reading horror stories of the tube cooking the wires.
    I've been looking at special high heat silicone/fibergl*** wire sleeve good to about 550° F, but I looked on the shelf and I have some ***anium exhaust wrap.
    Any problem using that to wrap the wires then run through the tube?
  2. I think I'd just re-route the wires to eliminate the problem...
  3. mr.chevrolet
    mr.chevrolet
    go find a junker piece of commercial food service equipment, say, an electric convection oven, they are full of high temp insulated wiring
    Hotrodjohn71 likes this.
  4. '29 Gizmo
    '29 Gizmo
    from UK
    There is an equivalent product for just that. Same stuff but in sleeve form, so yes it will be fine.
  5. 1971BB427
    1971BB427
    from Oregon
    I use black header and exhaust wrap in any place where wiring or brake lines might get heated from headers. I hate the stuff on header tubes as it just causes rust. But to protect wiring and brake lines it does a great job, and tied with proper SS wrap ties it looks good and does the job. The black is much nicer than white or brown I've seen.
  6. another 20 dollar cure for a 10 cent problem. If I was worried about the metal tube (yes I have seen cooked wires) I would just move the wires.
    The tube was not a heat shield by the way it was a wire loom to route wires away from the heat and worked well until someone left the bolt out that holds it in place or the little bracket broke off.
    Hotrodjohn71, NoelC and Bandit Billy like this.
  7. Bandit Billy
    Bandit Billy
    Good one PnB, I have got to remember that one.
  8. Doublepumper
    Doublepumper
    from OR-WA, USA
    If the tube will accommodate it, pull the wires and wrap them individually with some high heat fibergl*** tape and re-***emble them back into the tube.
  9. Just Gary
    Just Gary
    Cut a piece of heater or vacuum hose lengthwise & run the wires through it instead of the steel tube.
    The rubber is a great insulator & it prevents chafing too. :)
    Hotrodjohn71 and firstinsteele like this.
  10. Hotrodjohn71
    Hotrodjohn71
    Thank you all for the great info.
  11. H380
    H380
    from Louisiana
