titling a rod?
Discussion in 'The Hokey Ass Message Board' started by sonic reducer, May 13, 2006.
  1. sonic reducer
    sonic reducer
    what is the process to go through when ***ling an old pile of parts?
    I'm talking a rusty old T bucket, hommade 2x3 frame, 350/350, some 40's truck parts, etc. no ***le whatsoever.
    how about insurance? this thing is going to be an insurers nightmare I'm sure. I do have an ok driving record, only a few small speeding tickets for 10 over.
  2. fordcragar
    fordcragar
    from Yakima WA.
    Check this out:
    http://www.jalopyjournal.com/forum/showthread.php?t=104566
  3. scottybaccus
    scottybaccus
    I just gathered the facts for Texas. Here's the rundown. I would expect most states to be similar.
    If you have a ***le of any kind that can be linked to a number on the body or frame, you ***le normally, unless vehicle was declared totaled at any point in the past. If you have a salvage ***le, you also use these steps.
    If you have no ***le of any kind, you will need to do the following...
    Finish out the car with all required safety equipment. This will be more like a new car unless you can prove that the majority of the vehicle is older than a certain age. The reaosn being, a car constructed now of primarily reproduction parts will be ***led as a new car. (I may have a 2007 model '38 Chevy this time next year!)
    Complete a Rebuilt Affadavit (form VTR-61)
    This is a sworn statement that all parts were aquired legally, it also has a listing of major components and all identifying numbers. You must also provide sources for these parts and proof of purchase.
    Complete an Application for an ***igned VIN (form VTR-68A)
    This ***erts the same information as the form above, but also includes an inspection by law enforcement to make sure you didn't steal it. They check everything to be true as you state. Usually performed by a state or local auto theft division.
    Complete an Application for Certificate of ***le (form 130-U)
    This is the normal application for ***le used when buying a new or used vehicle.
    Go through these steps, complete the inspection process and then submit all these do***ents with the required fees (about $12, don't lose your receipts for major components. They prove that you already paid the sales tax) then you can register the car and get a safety inspection as usual. The ***le may call your car a "replica". Again, if you have no ***le to start with, it will result in your car being labeled as the current year model. That means you have to meet all the same emmisions standards as a new car. In Texas, it will be exempt from the sniffer for 2 years in counties that require that. After that, it had better be clean. The need for cats, etc. is still kinda gray, but I doubt anything will p*** a sniffer without. I plan to use propane to be sure I am exempt.
    Hope this gives you an idea of what to expect.
    Good luck,
  4. 23 bucket-t
    23 bucket-t
    I do not know about your state but here is Connecticut you do not need a ***le for a car over 25 years and about insurance that should be not a problem you should be able to get cl***ic car insurance. I went thru my daily auto { Allstate and my insurance agent got me Hagerty Cl***ic Car Insurance } Good Luck ........ and welcome to the H.A.M.B.
  5. sonic reducer
    sonic reducer
    any CO folks done it?
