To Chop Or Not To Chop
Discussion in 'The Hokey Ass Message Board' started by 1lowtrk, Feb 5, 2005.
  1. 1lowtrk
    1lowtrk
    Im tryin to decide if i should chop it 3" or leave it alone It being a 51 chevy 1/2 ton 5 window pickup. if i do id like to keep the wing windows,visor and driprails.I also would like to drop the center rear window down so it will match the side widows. Should i do it and is it doable?I already built a new ch***is nosed it and suicided the doors so the welding is no problem but the cuting is. I know about measureing the front post verticaly and bracing everything but it looks like i will have 5 pieces to weld back together.Seams like alot.any thing else im missin?
  2. Aaron51chevy
    Aaron51chevy
    I would chop it, those trucks look sooo much better lower. BUT I don't know what you'd do about the side windows??
    I have a similar delemma with my 51 sedan, chop it or not?? I figure I'll get mine runnin first then chop it next winter or somethin.
  3. hudsoncustom
    hudsoncustom
    Chop 3 1/2", section 3" and lower that damn rear window. Loose the visor. FWIW>..
  4. The Shocker
    The Shocker
    Chop it ,if you have never done one I applaud you.Just remember the more you take out the harder it is to get everthing to line back up.I always start out conservetive and take off more a half inch at a time until I get the evil look.Good luck...
  5. The Shocker
    The Shocker
  6. Primo
    Primo
    Chop it. :)
    Primo
  7. nuth'ins cooler than one these babies chopped, but it ain't no picnic either. I chopped a '53 F100 about 20 years ago, looked really cool, but I decided I f**ked up and ended up putting it back to stock. The doors fit better then they did from the factory when I got finished.
    I still had alot of fun and learned alot too, maybe that's why I haven't tried it since?!
    Good luck on whatever you decide, man.
    slacker
  8. oh yeah, chop it... my buddy chopped his 3" and sectioned it 4", looks damn good i think. its on the stock frame in the pic, hes got a full hand made frame with C4 vette suspension which puts the running boards 4" from the ground... chop it.
  9. Tim
    Tim
    from KCMO
    lose the visor and chop it MILDLY, i think if you ditch the visor and makeit s**** the ground that it looks fine unchoped. but they do look great with a hair cut.
    the quarter windows? sink them down into the body ;) some one has pix of how this is done im sure
  10. Rocknrod
    Rocknrod
    from NC, USA
    I think if you do chop it, you lower it down, trim the fenders down and widen the hood and grill..
    Gotta do the package or it doesnt quite look right. "right" is relative though!
    But, dont go wild on any of it or you p*** "Wicked" and can get overdone in a heart beat!
  11. InjectorTim
    InjectorTim
    I would definately leave the 5 window alone. It would be a different story with a regular cab, bu the 5 windows are already soo cool as they are.
  12. jerry
    jerry
    Loose the visor, leave it unchopped, lower the hell out of it!
    jerry
  13. Tim
    Tim
    from KCMO
    hmm lol nevermind i guess that truck aint gona get a whole hell of alot lower lol, so just ditch the visor
  14. chad
    chad
  15. Muttley
    Muttley
    Why does everyone like the 5 windows so much? They would look so much better if all the windows in the back were the same height.
    BTW NO CHOP.
  16. springer
    springer
    I am thinking of buying a 52 and I have looked at a lot of pictures. I think they look best with a mild chop and a lot of lowering.
  17. Snake9t9
    Snake9t9
    IMO Chop it and pie cut section the hood front to back.
  18. madgrinder
    madgrinder
    ALL things are better chopped...
    Section the cab and pie-cut the hood so the cab and bed flow better.
  19. bbo
    bbo
    from Wylie, Tx
    Cut it up. Not just the top but section, smooth, widen, drop, round, channel and when thats done bag it. Not too much, not too little, just enough will be fine.
  20. Joe King
    Joe King
    add 2 inches ??
  21. Conder
    Conder
    *Chop it too much
    *Lower it too much
    *Flame the @#$% out of it
    *Take Kung Fu lessons
  22. jangleguy
    jangleguy
    Anything's doable, and choppin' that truck has gotta be one of the easier things in life to do...Having said that - I've been looking at these trucks a lot lately (want one for my new daily driver), and decided that I wouldn't chop it, because it'd lose the "innocence" that attracted me to it in the first place. Does that make any sense? I'm shootin' for a stance about like yours, and leaving the tall top just visually lowers it even more...But like I said, that's for a daily driver that I don't want to stand out that much anyway. If I were going to really hot rod it - well...I'd need fresh blades for the sawzall............
  23. rustyparts
    rustyparts
    from Clinton,Mt
    Chop the hell out of it!:D
  24. Mojo
    Mojo
    A photochop I did some time ago. Imagine the frame is Z'ed, the frontend and bed are raised up. The hood is sectioned to match up with the cab. If the frame is Z'ed (not the cab channeled over it), there should be some room left to sit in it...
  25. Leave it as it is height-wise, mix up a batch of UV resistant industrial gray primer and toss in a **** load of micro-flake (just did this on my son's trike and it's *****en). Set it on some Astros w/ skinny whites and leave the visor. Mexicali cool.
  26. Jaypee
    Jaypee
    from Finland
    Leave it unchopped and slam it to the ground.
    Jaypee
  27. outkast
    outkast
    go ahead chop it, hell you only live once!!!
  28. caseyjones
    caseyjones
    I think the proportions go bad if you just chop the top...the cab from the beltline up is narrower than the doors, so if the the truck is chopped but not channelled it ends up looking like a squashed snowman. I guess I'm partial though, this truck is in my family...
  29. 1lowtrk
    1lowtrk
    Well the trucks already low.Its baged and the frame frome the cab back is 2x4 tubing that is z'd.I had to c notch the crossmember under the cab for driveshaft clearance. the front is mustang 2(witch by the way ****s!) w/bags.Its also my daily driver so i gota find somtin else to drive while i chop it (i decided to chop 3"). ill be startin in a few days Ill post some picks along the way
  30. chad
    chad
    Good call.....
