To LS or Not to LS
Discussion in 'Off Topic Hot Rods & Customs' started by Jon Kauffman, Apr 23, 2026.
  1. Jon Kauffman
    Jon Kauffman
    Came across this ’59 Pontiac Safari wagon over on BaT and thought it was worth sharing here.
    Such a rare Canadian car, cl***y looking but not overdone. Built for touring with the LS, power steering and power brakes. You don’t see many of these that survived the wreckers.
    I’m curious what you guys think about the details—I love the take on an original color but with the contrasting roof and wheels. Also wondering if anyone knows much about how these Safaris were optioned back then… clearly not with a 5.3L LS! I know there are purists that won’t like that, but if you were building a car to road trip in, would you sacrifice purity for reliability and go for an LS? Would you rather power steering and power brakes than an all original stamp of approval?
    Always liked these late ‘50s wagons...unbelievable body lines and so much character!
    hotrodjack33 likes this.
  2. squirrel
    Power steering and brakes were more common on the more expensive cars, you'd expect those options to have been ordered on a typical Buick, but not a typical Pontiac.
    Putting the modern belly ****on motor in a car like that is a sensible thing to do, seems that a lot more folks these days know how to deal with modern drivetrains, than with the old ones. Sure takes it "off topic" on the HAMB, though.
  3. gene-koning
    gene-koning
    The wagon looks pretty good, for now. Those little bubbles under the paint on the doors are rust holes under filler that are about to get much worse. I suspect that the doors are not the only place filler was used to cover rust. In another year, that car probably won't look that pretty. To correctly repair the amount of rust I suspect may be hiding under that paint won't be cheap.
    If you don't mind brown rust spots showing up on your shiny blue paint, you may have a few years before it gets really bad looking.
    The car looks like it might be a nice cruiser, other then the rust. The LS motor is the GM equivalent to the 283 from the late 50s, seems to be the go to motor for a lot of people. They make good power, are plentiful, and parts will be available for a long time. Many have the over drive transmissions which makes driving on the highways more fuel efficient. I have nothing against the modern drive trains in the old cars. They make great cruisers. The purest are always unhappy, not my problem.
  4. Scott Danforth
    Scott Danforth
    With rebuild costs near $2000 for machine shop alone, a low mileage LS motor and transmission are $500. For under $1k you can go twin turbos and have reliable tire shredding power
    Why not go LS or LT these days?
    All vehicles with an LS or LT have an overdrive trans, be it 4,6,8, or 10 speed automatic, or 5 and 6 speed manuals
    The 4.8 is 292 cubes 5.3 is 325 cubic inches, 5.7 is 348 cubes, 6.0 is 366 and the 6.2 is 377
    However power density is about double if not triple the original stock Gen 1 SBC because of the recardo combustion chamber
    Just like the original small block was swapped into cars 70 years ago when it came out. The Gen 3/4/5 small block are being swapped in and getting 20mpg
    firstinsteele likes this.
  5. squirrel
    lmao...I ended up with $15k in my Cheep (6.0 single turbo that runs 10s). They're kind of cheap to build, but not that cheap.
  6. pprather
    pprather
    I'd drive that!
  7. Moriarity
    Moriarity
    SUPER MODERATOR
    So this is your car and you are currently selling it on BAT?
  8. Jon Kauffman
    Jon Kauffman
    Yessir it is… I’m looking down the road and debating if I would go the LS route again so was looking for in biased feedback from “those in the know”. It has been super nice to drive, but as I’m sure many of you know, it’s not for everyone
  9. 19Eddy30
    19Eddy30
    from VA
    LS ,
    carb it
    Intake, MSD box or other .
    Spend more $$ as you go .
  10. No. But that's just my option, it's your car.
  11. pprather
    pprather
    Just drive it and enjoy it.
    Duellym and firstinsteele like this.
  12. Mr. Sinister
    Mr. Sinister
    from Elkton, MD
    If power/performance are any consideration, the SBC can and will make the same if not more power than the LS when modified to the same specs. If you just want to plop a stock engine in your car from the local pull-a-part, the LS is the way to go. Way more power and efficiency than any SBC.
    Duellym likes this.
  13. mustangsix
    mustangsix
    If you only drive it to car shows, restore it.
    If you plan to take it on road trips, DD, or use it to carry stuff, LS with OD trans, AC, PS, modern disc brakes.
    Cost wise, it's probably the same.
  14. AldeanFan
    AldeanFan
    My friend has a ‘57 Chevy with a 4.8 LS with stock fuel injection and a turbo 400. It has manual steering and brakes.
    My ‘54 Country Squire has a 292 Yblock and Holley carb, AOD trans, power steering and power brakes.
    My car is much nicer to drive, has been much more reliable and I’m not ashamed to open the hood at car shows.
    I have nothing against LS swaps but it’s not the answer for everything.
    Charlie K, Duellym and RMcCulley like this.
  15. oldiron 440
    oldiron 440
    I suppose the LS would be ok if you could keep the hood down but it’s one fugly engine.
  16. Moriarity
    Moriarity
    SUPER MODERATOR
    I would imagine that the OP will not be back. The bring a trlr link that used to be in his first post was him selling the car, seems he was here only to pimp the auction and he has not been back since I removed the BAT link
  17. twenty8
    twenty8
    I don't think we will miss him.......
  18. jfreakofkorn
    jfreakofkorn
    i would nt go LS
    but that me , old school all the way , imo
    Damon777 and Duellym like this.
  19. Duellym
    Duellym
    if I wanted fuel injection, coil on plug ignition, a modern electronically shifted auto trans and power everything inside the car I wouldn't look for a car from 1959. But hey that's just my opinion and clearly I'm in a minority there with how common LS swaps are nowadays
    Ned Ludd likes this.
  20. Damon777
    Damon777
    I used to be all over LS swaps in whatever. In my old age, I have come to agree with Matt Martin on the subject.
    https://www.nailheadbuick.com/post/the-ls-swap-fad-and-styling-continuity
    I will maintain that almost any engine can be reliable so long as it is maintained properly. The engine in my avatar starts right up, even at -3°F. The only "upgrades" I have done are 12V conversion and a pertronix.
  21. Deuces
    Deuces
  22. chevy57dude
    chevy57dude
    I love how the op indicated the LS is more reliable than a vintage engine. Like the original '59 Pontiac 389 couldn't be trusted.
    lumpy 63 likes this.
  23. DuraGlide
    DuraGlide
    I'll just leave this here since the OP has left the building it would appear.
    Duellym and lumpy 63 like this.
  24. Scarebird
    Scarebird
    Alliance Vendor
    from Moita, PT
    L84 1000 pixel.jpg It depends on what your goal is.
    The stroked 400 (440) in my 71 Lemans got horrifying mileage (9 mpg) and not enough power to warrant the fuel cost - especially here where fuel is $7.50/gallon. I found a 2019 L84 crate motor (5.3 direct injection) and installed it with a TKO. Excellent power, good mileage but added complexity/much less support vs. a Gen 3/4 LS.
    Were I to do this again I would suffer a 10% degradation in mileage and run a LS3 crate like another car I had. Superb power and better reliability. I would have kept the M22Z also, just for that Rockcrusher whine.
  25. finn
    finn
    Just say NO to the thought of an LS swap.
    I walk right past anything that has an LS at a cruise night, car show, or swap meet car corral.
    Moriarity and chevy57dude like this.
  26. squirrel
    yup, whether or not to do an LS swap should depend entirely on whether you're doing it to make your car nice to drive, or to impress other people.
  27. A Boner
    A Boner
    LS with a full hood!
    dogwalkin likes this.
  28. Scott Danforth
    Scott Danforth
    Here is the LS I am doing for the Fiat Build. The intake is a Victor Jr. 4150 and will be purchased with the injector bungs in the event I decide to go twin turbo and EFI at some point.
    they dont have to remain fugly with plastic intakes and coils hanging out on top the motor.
    once stripped and dressed properly, its hard to tell what it is.
    dogwalkin, 19Eddy30 and leon bee like this.
  29. Bandit Billy
    Bandit Billy
    Our local wrecking yard recently advertised a supercharged LS7 with TKO 6 speed with harness for under 10k. You absolutely cannot beat that. Keep the hood closed, your mouth shut and hold the F on.
    dogwalkin and SS327 like this.
  30. Scarebird
    Scarebird
    Alliance Vendor
    from Moita, PT
    Billy, on that listing - did they include the PCM too?
    Wrecking yards have a really ****ty habit of selling all but the PCM, they do that separately.
