To Raise or Not?
Discussion in 'The Hokey Ass Message Board' started by Rusty, Apr 27, 2006.
  1. Rusty
    Rusty
    Got this tri-power set up yesterday to replace the crappy set I got of the other site and it came with these cool OFFY carburetor risers. Mocked it up to see how it looked and just aint sure of it. What do you think??
    another side
    Heres the other carbs before
  2. tommy
    tommy
    I like anything that makes your car/engine different from the others in the lot. Some may argue any miniscule performance advantages or disadvantages but for me I think they look cool because you don't see 'em everyday.:D
  3. Kevin Lee
    Kevin Lee
    Super Moderator
    Only my opinion - I don't like the risers. It's just the aesthetics for me.
  4. DeuceDog
    DeuceDog
    from Breese, IL
    Not sure...can you get a 3/4 shot of the entire car?
    John
  5. nrfleming
    nrfleming
    i say use them. the higher the better...but i like tunnel ram just because it looks cool.
  6. can you get a shot standing a little further away to get the whole stance????
    I think it looks sort a goofy right off. I have some of those too and I ain't sure about them either.
  7. you may loose a little bottom end torque
    oh wait its a nailhead.... you have torque to spare:D
    NICE
    tom
  8. ig'nant
    ig'nant
    I don't think it needs 'em, but they would be a cool conversation piece. As easy as those would be to swap, I'd just add/delete/add 'em just for fun, whenever the mood hits ya.
  9. Brewton
    Brewton
    Have you driven with the spacer on it yet? Looks OK - how they perform is what I would base wether I kept them on or not.
  10. Thirdyfivepickup
    Thirdyfivepickup
    Exactly! Its nothing to swap them out! Drive it and let the seat of your pants be the judge!
    From a visual POV... I agree that we need a shot from further away.
  11. DrJ
    DrJ
    On a HOT ROD, there's gotta be a performance reason to use them, not just "they look cool".
    The air velocity change they would make will either enhance or degrade power at different RPMs.
    If the increase power at higher RPM then they might drop it at low RPM, or maybe the other way around, that all depends on the rest of the engine.
    Since it's progressive linkage, it might get best bottom end with no riser in the middle carb but gain power from having them under the end carbs, or the other way around.
    Only testing would tell you the answers to that.
    Running either one in the middle and none on the ends, or one on each end and none in the middle will probably give you the best power setup, regardless of looking gooky or making linkage a nightmare.
    What I'm thinking and comparing it to is those 4 carb manifolds that ran one larger bore carb than the other three because it supposedly balanced the uneven firing order demands.
  12. tommy
    tommy
    The Burns dual manifold for the flathead came with or without the unboltable risers. Their literature said the risers can be removed to change it from a "high commercial model" to the low racing type manifold.:D
  13. HolyHandGrenade
    HolyHandGrenade
    I like the look of the risers personally. I like how it puts the air cleaners between the braces.
  14. Dirk35
    Dirk35
    The most important thing here is: Do you like them?
    I personally think that is already a killer looking intake and carbs w/o the spacers. If the spacers dont make you like to look of it better, help it run better, or make it easier to run fuel line, or clear a distributor, or set up a throtle cable easier, or give better MPG, Id say why bother?
  15. Dirty2
    Dirty2
    Give em to me and I will run em . :D
  16. Rusty
    Rusty
    Their yours!! Moving on to bigger and better things the Dirty2 Sedan, Thanks everyone.
  17. definately like the before pic better.. imo
  18. buzzard
    buzzard
    Alliance Member
    HaHa, when in doubt, give 'em to yer ol' man!
