History Tom Cobbs: Project Car
Discussion in 'Traditional Hot Rods' started by Ryan, Dec 17, 2025.
  1. Ryan
    Ryan
    ADMINISTRATOR
    Ryan submitted a new blog post:
  2. flatheadpete
    flatheadpete
    from Burton, MI
    That T roadster is beyond cool.
  3. Higher
    Higher
    Isn't the third picture a -29 roadster? Which makes it 3 cars?
    Sharpone, hrm2k, Tim and 2 others like this.
  4. Ryan
    Ryan
    ADMINISTRATOR
    Awe ****... That image doesn't belong in this batch. I must have added it to the gallery by mistake. That's an early mockup of Tom's roadster.
    In any case, I believe it was taken at Tom's parent's house in the late 1940's. You can tell it was a pretty nice joint.
    Sharpone, hrm2k, Higher and 2 others like this.
  5. Moriarity
    Moriarity
    SUPER MODERATOR
    pure genius....
    Sharpone and porkshop like this.
  6. Dave G in Gansevoort
    from Upstate NY
    I wonder exactly what frame was used. Look closely and you can see that there is a weld seam in front of the rear kick up. IMG_0429.jpeg
    tractorguy, Sharpone, Outback and 2 others like this.
  7. Tim
    Tim
    from KCMO
    I think it’s a 34 ford frame with a fabricated section to get the rear stepped up. It’s way more “step” than the Chevy and other early cars that got used for the rear step up.
    What a fantastic journal entry! That T roadster is fantastic in every way and has me wondering if they still make those rear tires and if so can I get a 750/16.
    You could print those out poster size and stare at them for an entire Christmas break that’s for sure.
    The second/ third car is a head scratcher. Reading the parts list, seeing the torsion bars, it was giving me pikes peak special. But seeing the photos, something about the mid fifties time stamp, the short wheel base, the wire wheels and the doors mocked up make it feel closer to the home made sports cars of the era.
    Very cool whatever is or was.
    Sharpone, porkshop and 3blapcam like this.
  8. Ryan
    Ryan
    ADMINISTRATOR
    Yeah, that's a '34 Ford frame for sure...
    As for the head scratcher, I wonder if it wasn't something Tom was preparing for local hill climbs? He had a history not only with pikes peak, but:
    https://www.jalopyjournal.com/?p=62597
    Sharpone, hrm2k and Tim like this.
  9. Equipped28
    Equipped28
    I’d say it’s definitely the freudiger roadster, not just the cowl cut but wishbone placement, channel etc all tally up aswell as the need for a wide nose on the car because of the straight 34 rails, rear wheels/caps look like the ones he sometime ran on his A roadster too accessory wide 5 maybe?
    I like the lower part of an edelbrock slingshot used on the manifold, if you look at his later set ups when he made the log manifold he’s still using that intake flange with the same shape and bolt pattern.
    in the archive is there any more in depth photos of the blower mount? It looks to be welded to a timing cover. And also the drive he used? Or does whoever that own’s the motor now have some? It would be helpful for us and our coupe endeavours.
    Sharpone, rod1, Outback and 4 others like this.
  10. Ryan
    Ryan
    ADMINISTRATOR
    I'm posting the archive as I open it... pretty much in real time... You can see everything I've seen thus far here:
    https://www.jalopyjournal.com/?s="Tom+Cobbs"
    Tardel recently acquired what we think might be the first blower Tom used on his roadster. I plan on shooting it at some point. But man, if there is anything I've learned from the archive it's that Tom spent a lot of time on blower setups and used a variety of intake setups, mounts, pulleys, etc...
    chlsnk, rod1, Sharpone and 7 others like this.
  11. Tim
    Tim
    from KCMO
    Travis over at rhode alliance customs has one of the 4-71? Blowers and carb set ups from Tom as well. Got it off Joe a few years ago.
    Sharpone, Outback, hrm2k and 2 others like this.
  12. GuyW
    GuyW
    Check out that finned oil pan.
    tractorguy, Sharpone, hrm2k and 2 others like this.
  13. Tim
    Tim
    from KCMO
    Yeah the pan made me think of the finned pans I always see on Ardun flatheads
  14. justabeater37
    justabeater37
    That lead photo just makes me want to put a magneto in one of my flatheads even more. Someday...
    chlsnk, Sharpone, Outback and 2 others like this.
  15. alchemy
    alchemy
    The quickie in the second car looks familiar.
    tractorguy, brad2v, winduptoy and 6 others like this.
  16. Ryan
    Ryan
    ADMINISTRATOR
  17. flyn schlosser
    flyn schlosser
    from Elko,NV
    Pure hot rod history.... just love it....
  18. Michael Ottavi
    Michael Ottavi
    What possible reason for such a short wheel base in the last build? Must of been a hand full in the handling department?
  19. Ryan
    Ryan
    ADMINISTRATOR
    That's why I think this car was probably envisioned as a hill climb car. Early hill climbers put an emphasis on shorter wheel bases for a few reasons:
    1. Agility.
    2. Lower Turn Inertia... basically, you can rotate the car easier.
    3. Lighter and stiffer.
    I'm not a huge hill climb guy, but as I understand it this was sort of over-emphasized until the later 1960's or so...
  20. corncobcoupe
    corncobcoupe
    SUPER MODERATOR
    History....priceless
  21. Hollywood-East
    Hollywood-East
    Could that be the ch***is for the aluminum body there was a single Pic. In one post, an a receipt in another post ??
    porkshop and Sharpone like this.
  22. Sharpone
    Sharpone
    IMG_3731.jpeg When were these shot? Everything on this is beyond cool but the pipes um um I got no words.
    Dan
    tractorguy and porkshop like this.
  23. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    A la "So-Cal Coupe..."
    41 GMC K-18, CSPIDY, porkshop and 3 others like this.
  24. Tim
    Tim
    from KCMO
    So flex pipe headers are a detail everyone seems to be blind to. Crack open any, I mean ANY book on hot rodding in the post war era and you will find flex pipe headers. Extremely common.
    it’s one of those details that people never notice until they look for it, and then it’s everywhere.
    one for me was cross steer ford steering box’s ( 1946 type) turned side ways with the sector pointing out under the frame rail with the pit man arm pointed up to use it for side steer. I saw one car, and then I saw twenty lol.
    hot rodding details are very easy to miss if you weren’t looking for that specific thing
  25. cfmvw
    cfmvw
    That short wheelbase car is interesting. I would like to see the completed project if any photos of it exist.
  26. Ryan
    Ryan
    ADMINISTRATOR
    The short wheel base car photos were developed in October of 1956. I ***ume the roadster shots were around the same time or a little earlier, but I have no way of knowing.
    So true... Particularly at Bonneville and on non-traditional layouts of motors to frames, etc... Flex pipe was everywhere.
    I think we ignore it because it garnered such a bad reputation afterwards...
    I don't know that the car was ever finished. I guess we will see as we continue through the archive.
    54delray, tractorguy, Tim and 5 others like this.
  27. Equipped28
    Equipped28
    So I’ve been having abit more of in-depth think about this, drifting away into nostalgia whilst trying to work, with the blower set up in a semi finished state and knowing it was finished and ran in the so cal coupe in 53 and then again in 54’ when he ran it in the ex Pierson coupe. I think he was building this T maybe 52/53? Aiming to run this car and then the coupe came up for sale, an already proven race car in which he did some modifications and threw his blown flathead in.
    this shot of the roadster is apparently from 56’ when Cobbs was then campaigning the small block in the coupe, so with the surplus flathead sitting there, here it is back in the T in the hands of Freudiger, so wether it was his car all along and Tom just built it or he bought it when the coupe came along. I think it’s neat he was pushing several records at the same time.
    or I could be totally talking ****, It’s been known to happen!
  28. Ryan
    Ryan
    ADMINISTRATOR
    No, that was exactly my line of thinking too. I am almost certain Tom bought the car in 1951, because I have a bill of sale that lines up perfectly with that timeline I think... The plan, at least at first, seems to have been to get it sorted and ready to race. That makes sense.
    Then the coupe opportunity came along and all bets were off. You do not say no to something like that. So the roadster gets sold to Freudiger with a promise attached, that Tom would circle back and help him with it once the coupe projected was lived.
    That feels right. That feels like how those decisions actually got made...
  29. Jack Rice
    Jack Rice
    As an uneducated flathead admirer, how does one spin those water pumps with this arrangement?
  30. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    Maybe the bracket in the intake between the Vee was meant to get an idler so the belt(s) could p*** over the blower drive??? With a magneto it wouldn't have needed a generaor.
    y'sguy likes this.
