Projects Tomcat’s Crazy '31 Model A Build Thread (2010-?)
Discussion in 'The Hokey Ass Message Board' started by tomcat11, Feb 16, 2023.
  1. winduptoy
    winduptoy
    I reread the entire thread...and am so impressed with everything you have persevered through.
    Thank you for the level of detail in your photo posts!
    Your vision and execution to date is of a master craftsman...I am a hack...
    I know mechanical brakes so no help with what's going on with that parking brake linkage....oh, its mechanical...
    looks like the iron termites worked it over...that that part was acceptable to use in an ***embly....hard to accept
    Think about how far you have come and what you have accomplished...
    Larry
    loudbang, rod1 and tomcat11 like this.
  2. tomcat11
    tomcat11
    @winduptoy Thank you for the kind words and all the likes Larry. It's been a long road and quite the challenge at times, but I'm hell bent on driving this thing. Oh, and I'm sure you are no hack! Keep the shinny side up!
    Tom
    winduptoy, loudbang and rod1 like this.
  3. tomcat11
    tomcat11
    Good morning everyone. Here's the latest on my project. Been working on a number of small, boring, but important details. A lot of time spent hand fabricating small brackets and things and just figuring where on the ch***is these things will fit and function.
    The Yukon bearing retainers came in a while back and they are a much better part. Blanchard ground flat, plated and with proper 3/8" holes.
    A small tab to mount the speedometer cable and keep it from rubbing on things like the brake pedal arm. Space is tight everywhere and an 1/8" here or there makes a difference.
    Rear Axle housing drilled and tapped for the vent and brake hose mounting.
    Using the Rock Auto parts catalog I found a rear brake hose for a '68 F100 that is a good fit. The Pete & Jakes brake hose tab got shortened and tacked in place.
    Suspension travel at full compression to check for any interference with the floor.
    Next was to figure a way to finish routing the parking brake cables so they don't hit the drive shaft. This took quite a bit of time to work out. I finally came up with this bracket and it should do the trick.
    Here again, the suspension and drive shaft are raised to the highest possible position to make sure the cables clear absolutely everything before t******* the cables to the final length.
    Next up was rear axle bump stops. I found these front lower control arm bumpers that were used on pre-1962 Chevrolets. The first set of bumper brackets got trashed after realizing the axle was not quite squared up and would not hit the center of the axle tube. The axle also moves forward about a 1/4" at the contact point.
    I'm guessing if the axle ever hit's the bumpers they will compress maybe a 1/2"? Once again space it at a premium, too short and the housing hits the floor and too long limits the compression travel.
    Here is the second set of brackets with some 1/4" thick SST spacers to extend the length.
    In between all that, I managed to remove the rust from these brake parts by soaking them in a mixture of hot water and wood bleach (Oxalic Acid).
    After marinating them for a few hours the grooves from years of wear got filled with weld rod then metal finished. I have a little plastic blast cabinet that Western Auto used to sell. Remember them? After blasting they got shot with some 20+ year old Dupli-Color High Temp paint that I found in my stash. This stuff is still good!
    That's all for now, happy Hot Rodding:cool:
    AHotRod, alanp561, Deutscher and 14 others like this.
  4. vtwhead
    vtwhead
    Pretty slick fab work Tom. If I didn't know better I would say you must have an engineering background what with all the attention to details of every item. Impressive stuff.
    loudbang and winduptoy like this.
  5. tomcat11
    tomcat11
    Thanks @vtwhead. Yeah, I think sweating the details is the key to success. I did work at a National Lab for 39 years in the Science & Engineering field. I learned a lot along the way from people way smarter than me. Over the years I tried to apply what had learned to my racing endeavors to give me a bit of an edge. Racing has always been my true p***ion. Now, I'm just taking the same approach here. Hard to break old habits I guess:D.
    Deutscher, rod1, loudbang and 4 others like this.
  6. 05snopro440
    05snopro440
    As a detail-oriented engineer, you're doing great work. It's a pleasure to see your solutions to problems that arise.
  7. tomcat11
    tomcat11
    Thanks for following along @05snopro440. Yep, lots of problems have cropped up along the way. Sometimes I brush off the seemingly simple things only to find out later they are a bit more challenging. The main problem always seems to be how to package everything into such a small car.
    P.S. If you see something I missed or screwed up, don't be shy. let me know. Cheers.
    vtwhead, 05snopro440 and deadbeat like this.
  8. tomcat11
    tomcat11
    So here's another update. I decided to go ahead and mock up the last two rear body mounts. That required removing a couple square nuts that were welded inside the frame and that's when another can of worms broke open. In any case I was not happy with the rear frame horns due to the shoddy fabrication from the previous builder along with several other issues as you will see.
    Nuts removed.
    Removing the nut revealed holes that are larger than I would like.
    I made this spot face tool to clean up the surface around the holes. The 3/8" I.D. sleeves I welded in the sub- rails served as a guide while driving it with a socket and impact gun. It worked quite well but ended up being a waste of time.
    Rear body mounts installed. That night I decided I could not live with these ****py rear frame horns. As you can see here, one of the issues is there is no clearance between the frame and the rear body crossmember.
    A couple years ago I had bought a couple new horns knowing I might need them.
    Amputation complete. Now the "fun" part begins.
    Here are some of the other issues and why they just needed to go.
    First step for the new horns was to narrow the top edge.
    Next was to plot where the body mounts would land and trim any excess material. Then think long and hard about where to notch and bend them so they come out at the right dimension and are parallel for the stainless steel spreader bar.
    This miss-match will also need to be addressed.
    Also thinking about how short to make them and how to clear the body.
    I ended up cutting notches in the horns to clear the body.
    Two bends in each horn were needed to make this come out right. A little tricky and one step at time trying not to screw this up!
    Once I had this all figured, I shortened the horns, drilled new holes for the spreader bar, and then made some "L" shaped filler pieces for the notches.
    Still more work to do on these but it's slowly getting there.....
    alanp561, Deutscher, akoutlaw and 7 others like this.
  9. winduptoy
    winduptoy
    You are a reconstructive surgeon... Dr.Tomcat
  10. continentaljohn
    continentaljohn
    Love your attention to details cool build
    winduptoy likes this.
  11. tomcat11
    tomcat11
    Thanks winduptoy! Unfortunately it is one hell of a long operation! :D
    @continentaljohn Thank you sir!
  12. tomcat11
    tomcat11
    So picking up where I left off on the rear frame horns. I welded the filler pieces into the notches.
    Metal finished welds and rounded corners.
    Next would be welding up the saw cuts at the bend lines.
    Knowing the angles would change after welding, I recorded the angles and decided to start with the single saw cut below the notches. Since these cuts are the furthest back, they would have the smallest effect on the finished dimension (39-1/2" Spreader Bar). This would also give me some idea of the angle change. I also hammered some filler rod flat and jammed it in the end of the cut and tacked that first.
    As expected the weld still shrank and I lost about a 1/2 degree on each horn. Fortunately, I was able to re-bend them and get back the lost angle. Before welding the remaining two saw cuts in each horn I over bent each one about 3/4 of a degree. This was a bit of a guess but, thankfully I had my desired angles after welding.
    I also needed to add about an 1/8" of material to the bottom flanges so they could be boxed in with gussets.
    Horns finished.
    Tacked in place.
    Constantly checking that 39-1/2" dimension and making sure things were pretty well centered.
    After fabricating the boxing gussets and with the mock up bar still in place it all got welded up. The last critical step was to match drill the holes for the rear body mounts.
    Body mounts from another angle.
    While grinding away body filler during this part of the project I uncovered even more ****py work from the previous builder. I guess I am going to repair this and finish off my welds when the body is back off the frame.
    I'm really regretting the decision to try and save this frame. What a mess.....
  13. tomcat11
    tomcat11
    Happy Labor Day everyone. August was a very rough month for me on a personal level but, I did manage to get some more work done on the car.
    I removed the retainer sleeve, check ball, and spring, from the rollover valve that came with Tanks Inc. fuel tank. polished it up and turned it into a rear axle vent. The clamp is an Adel clamp without the rubber and lands nicely on the barbed fitting.
    Tack welded a bunch of square 10-32 nuts to the inside flange of this floor panel for easier ***embly.
    As you can see the heat shrunk it causing it to crown, so it got ran back through the stretcher and is back to being flat.
    Drilled and dimpled holes in floor panels that will be rose welded to the subframe channels.
    Tacked up some 5/16-18 flanged nuts for the seat mounting brackets.
    A while back I had cut these thin L shaped spot welded tabs to separate this piece from the rear panel below the deck lid. I did this so that I could install the nuts and get some epoxy primer on the insides.
    Recently I realized the corners need to be attached to keep it in place and provide some support so I made some bolt on brackets from some 16 ga.
    Here it is bolted in.
    This is the trunk latch striker that came with the rear sheet metal pieces. A bit rough looking.
    So after smoothing it out......
    The damn thing interferes with the deck lid. So frustrating. Pretty sure it's bent wrong.
    Even the little "Ford licensed" rubber bumpers don't fit. I opened up the holes to match the groove diameter but they are hard as a ROCK! Even the simplest things on this car are a PAIN IN THE A$$!
    SS327, lurker mick, Deutscher and 3 others like this.
  14. pprather
    pprather
    It's coming together. Looking good!
  15. tomcat11
    tomcat11
    Thanks man! Just have to finish it before they start throwing dirt over me:D
  16. rod1
    rod1
    Your attention to detail always raises the bar to those that follow. Hope September is a better month for you .
    Weedburner 40 likes this.
  17. tomcat11
    tomcat11
    @rod1 Thank you for the kind post.
  18. tomcat11
    tomcat11
    Here's this week's work on this crazy *** project.
    Got the rubber Trunk bumper diameters and heights turned down to fit using dial calipers, the drill press, a 5/16" flat hd. screw, some double sided foam tape, some 80 grit sand paper, then 220 paper, and then finished off with some 400 & 600 grit paper. Took a light touch and lot of back and forth checking deck lid alignment.
    Then it was back to the trunk striker. Another part was ordered from Bratton's and of course it did not fit either. Quite a bit different from the Brookville part as you can see. Fortunately the height was lower.
    I had to burn off the coating off with a butane torch because acetone or paint remover would not cut it. Then I heated the bend at the bottom cherry red so I could try and change that angle. There's almost no way to grab this damn thing and re-bend it. After several different attempts I got it by clamping it to the weld table under a piece of steel bar and then prying on it with a pry bar. What a little *****!
    Then I noticed the feature in the sheet metal where this thing is supposed to sit was not sitting flush with the angle piece underneath and was bent up at the rear instead of down, so when I tightened down the rear screws the whole damn thing rocked back and pulled away the top. :mad::mad::mad:
    After taking a break I went back out and cobbled together a way to re-bend the sheet metal feature.
    Now it is flush.
    After making a 10-32 nut plate and tightening everything up the striker was a bit low and the latch would **** the deck lid down. I cured this with .075" shim under the striker to get it right.
    After cleaning up the edges and tool marks here it is finished, fitting, and functioning. I don't know what the hell Ford was thinking when they designed all this rear sheet metal. Getting all this to fit together right, especially with re-popped parts, has taken an insane amount of time.:D
    winduptoy, Deutscher, rod1 and 8 others like this.
  19. tomcat11
    tomcat11
    This past week I installed the License Plate light and the Tail Lights. Here's a cool little gem I picked up some years ago.
    Turns out the Vintique tail light mounting bolts are not perfectly centered in their housings and were slightly different from each other. I'm glad I checked before drilling any holes. After making patterns for each one I used some double sided sticky foam tape so I could move things around and get what I think looked pretty good.
    Since I'm not a huge fan of mounting things with sheet metal screws, I pressed some 8-32 PEM nuts into the rear panel to mount the License Light. A large .700" hole was needed for the 1/16" tall protruding feature on the rubber block that comes with the light.
    Another detail that will never be seen but is important is this rubber grommet for the wire that will come out behind the factory spare tire support.
    I know this basic look has been replicated a thousand times already but I have always liked it that is, as long as the lights are not mounted too far inboard. Down the road I'll make a bracket to mount the plate.
    :cool:
  20. tomcat11
    tomcat11
    Drive shaft loop modifications done. Shortened the "L" shaped brackets to fit the ch***is and shortened the top "U" shaped piece 3/4" and of course drilled new holes.
    Before;
    After;
    Clamped into position;
    dwollam, winduptoy, SS327 and 4 others like this.
  21. tomcat11
    tomcat11
    Been busy the last couple months resurrecting my off topic BBC drag car that hasn't run in 20 years. How time fly's. Well anyway, back to the coupe. While trying to get ready to pull the body and finish welding all the brackets on the frame, I realized I hadn't figured out how and where to hang the exhaust:oops:.
    My foolish vision is to have a polished SST exhausto_O. Sometime back, I had bought the header flanges, reducer cones, and mufflers. I now have the mandrel bends, most of the parts, and tooling to make this happen. What little space I have left will dictate where I can hang the mufflers so here we go.
    First step was improve the fit between the flanges and cones for welding. A cheap tail pipe expander was used to expand the cones and tighten up that fit.
    Next was to polish the flanges and cones. After 3 days work I decided they are good enough. These will get modified for the crank case evacuation system.
    I whipped up this wooden muffler caddy that I could bolt to my floor jack.
    That expander tool makes a handy way to hang on to these parts.
    A cheap way to back purge the welds is also coming together. Now back to your regular channel.
    dwollam, vtwhead, loudbang and 5 others like this.
  22. Outback
    Outback
    from NE Vic
    Thanks for the update, some lovely work on the exhaust pieces!
  23. tomcat11
    tomcat11
    Thanks Outback!
    Outback likes this.
