You might post your questions here. Lots of 35-36 guys. https://www.jalopyjournal.com/forum/threads/1935-1936-ford-pickup-tech-for-the-m***es.236409/
As others have posted, "great post!" I just did post on this forum, so, I hope a few will reply with a "magic" answer to my quest! The original owner installed a wooden (plywood) sliding cover. Great idea but 1) not water resistant/proof and 2) hard to remove. I'm hoping that one of the fibergl*** one-piece shells will work. However, can't find one for the flared style bed sides. I'll probably have to do a bit of retrofitting to make one fit. Thanks, again!
I have contemplated making my own using pink foam board and gluing fibergl*** sheets to it. Sandwich the foam in between. Similar to a motorhome siding. That way it's custom fit. I would use the original stake pockets to locate it.
I have been looking for something like the Tuxedo soft cover design that would keep the bed clean/dry but still allow it to roll up when you need to haul something.
Your other thread. Just in case there is any confusion. https://www.jalopyjournal.com/forum/threads/35-36-ford-pickup-tonneau-cover.1328926/
