Too Anal? Fed tubing question
Discussion in 'The Hokey Ass Message Board' started by deucegasser, Jul 23, 2010.
  1. deucegasser
    deucegasser
    If I'm buildin' an fed, should I be concerned about 1020 and 1018 tubing designations? I did find out it means machinability, but how does that affect bending and mig welding the tubes and/or flexibility? D.o.m. is what I want to use.
  2. Francisco Plumbero
    Francisco Plumbero
    from il.
    Are you gonna pass NHRA specs with mig welded components?
  3. hammer bowling
    hammer bowling
    Chrome moly can only be tig welded. D.O.M can be mig welded. D.O.M is good enuff for nascar so it should be good enuff for fed sportsman stuff.
  4. 1020 has slightly higher carbon content, but it's really nothing between the two. 1010 vs 1020 is a little different story. Shouldn't be any problem with fabrication, especially in the thickness you'll need to be legal.
  5. dreracecar
    dreracecar
    from so-cal
    Be careful when using mild steel tubing, even though its listed as .120 wall ,in realality its .114 wall and not legal, Thats why mild steel sportsman cars are .134 wall.
  6. deucegasser
    deucegasser
    Thanks guys. Is .120 wall the only size like that or do I take a mic. with me to the steel distributer? C'mon Racecar,reassure me.
  7. zman
    zman
    from Garner, NC
    Yes you can MIG weld chrome moly.
    Some sanctioning bodies require TIG in their rules though.
  8.
  9. Rootie Kazoootie
    Rootie Kazoootie
    from Colorado
    All tubing has a + or - tolerance in the wall thickness. The real problem lies in bending it for roll bars. As the tubing is bent it stretches or elongates thinning the wall thickness. This is why thicker than required tubing is often used for, at least, the rollbars.
  10. Mild steel tubing is legal the rules lump all mild steel tubing together dom is a lot more consistent and stronger than erw 1020 dom flexes nicely in a fed chassis
    sorry i had cap lock on
  11. rooman
    rooman
    Most mild steel tubing will be thinner than the nominal wall thickness in some (if not all) places (especially ERW). As stated most .120 nominal thickness tubing comes in at around .114 and .118 is required and that is why most door car chassis kits are bent out of .134 wall.
    DOM is usually a lot closer to the spec because it it made the same way as 4130 cm but it is nearly as expensive as 4130 when you account for the fact that you as buying more material due the the extra wall thickness required.
    Roo
  12. deucegasser
    deucegasser
    Consider me reassured. Time to order some tubing!!!!!
  13. hammer bowling
    hammer bowling
    Sorry Tman tig only on the chrome moly, dont want any pesky toe weld crack and fail and DIE situations.
  14. zman
    zman
    from Garner, NC
    first off it's a Z, second there is a difference between saying something can't be done and what happens if it's done wrong. You are WRONG. Chrome Moly can be MIG welded, period. If your skills aren't up to it that's not my fault. :D
    And really fill out your profile and do an intro.
  15. hammer bowling
    hammer bowling
    Forgot to post my quals and been seeing your all knowing posts for some time. I don't think I need to intro duce myself to someone like yourself that thinks you can weld chrome moly tubing safely with MIG. Good Day to you sir..............
  16. zman
    zman
    from Garner, NC
    well seeing as there are everyone from aircraft manufacturers using MIG on 4130 for their airframes, baja racers, motorcycle manufacturers on their frames, and on and on. You just really don't know. Getting and attitude about it makes it funny. Hotroddon was even nice enough to post the technical details for some of it.
  17. Ebbsspeed
    Ebbsspeed
    Hey hammer bowling, read rules #5 and 6 below, and maybe guideline #4. The following is copied from the "Read This First! post which you were supposed to read before posting anything on this forum.
    The HAMB is dedicated to spreading the gospel of traditional hot rods and kustoms to hoodlums world wide. That’s right – TRADITIONAL. And we aren’t talking Beach Boys and poodle skirts here fellas. If you are into a-side 50’s pop, lawn chairs, ruler contests, and all things that make hot rodding warm and cozy then you might want to find another message board. If you aren’t sure what we mean by “traditional”, then you might think twice as well. If you’ve come here to set a rep, talk some shit, and make some fun then you had better turn around right now. We aren't patient.
    Even if you have come here for all the right reasons, don’t expect posting to be easy. We don’t cater to new fellas unless they show a dedication to spreading this tradition of ours first. We welcome young, old, foreign and all – but our original members and our staff expect a certain level of respect and an effort to keep things true and on topic.
    Maybe you are an old fart with a past. Maybe you are one of the guys that started this tradition we cherrish. We built this place for you and your posts mean the world to us. Hop on and introduce yourself. This is your board.
    Still reading? Then you must be cut out for this, right? We recommend you read some more. Check out all the forums, develop an understanding for how things work around here, learn the “do’s” and “do not’s”… The key to a happy HAMB newbie is to understand the joint BEFORE you begin posting. You want to be happy don’t ya newbie?
    We have very few written rules here on the HAMB and that’s the way we like it, but we won’t hesitate to dump disruptive posters, ego freaks, or shit talkers. We are all here to learn and teach - please keep your other perogatives on the sidelines.
    Rules:
    1. No profanity in subject lines
    2. No political/religious/racial posts
    3. No Porn.
    4. All personal information listed on this board is private and protected. The HAMB does not sell this information and you are not privy to use it for your own reasons. Test us on this one and we will bite.
    5. New Users must fill out thier profiles. Every bit that you can. Simply click on "User Cp" above and get to work.
    6. New users must introduce themselves in the intro forum.
    Guidelines:
    1. If in doubt, don’t post it
    2. Stay on-topic and relevant with your posts… OT posts aren’t generally appreciated by our membership.
    3. Gotta easy question? Try using the search function first.
    4. Your life here would probably be easier if you complete your profile and introduce yourself before jumping into the deep end...
  18. rooman
    rooman
    I am right in the middle on this one as although as stated 4130 can be successfully MIG welded it is not a totally straightforward process as seen in the guidelines posted. When OEM style manufacturers MIG 4130 they have a bunch of engineering and hopefully a lot of testing of the final weldment to guide them. Doing it in a home shop environment is not the same, especially when using the thin wall tube that is the norm for a 4130 dragster frame. I see enough sub standard MIG welds on thick mild steel frames to be very worried about someone trying to stick 4130 together with anything other than a TIG welder.
    Of course if you can't weld properly with a MIG you probably won't do much better with a TIG but at least the process happens a little slower and for my mind is a little easier to control.
    Anyway the original question was re the spec of the mild steel so we are basically de-railing the thread and have no idea of how duecegasser plans to stick his frame together.
    Roo
  19. 4130 improperly welded causes accidents 2 guys I know are handicapped because of it their cages snapped at the welds and ended up with broken backs and this were pro-built
    use mild steel and be safe
  20. Littleman
    Littleman
    Alliance Member
    from OHIO, USA
    When in doubt.........fab it up yourself...tack it together ........and have it welded by a proven qualified welder..........Littleman
  21. fab32
    fab32
    After having manufactured short track oval racing chassis for 15 years for Howe Racing Enterprises (produced over 3000 chassis during that time) I can assure you that Chrome Moly CAN be sucessfully welded with Mig. It might pay for some here to do some research before posting definitive statements no matter what the subject. "old wives tales" do nothing to further the education of the many new guys that participate here.
    Frank
  22. HemiRambler
    HemiRambler
    Check your rule book CLOSELY. You can be certain the Chassis Inspector WILL be anal - it's his job to be!!!
  23. Mr48chev
    That should be the first consideration when building any race car chassis for any style of racing. Unless it is a display only cackle fest style car that will never make a pass down a strip it's time to research the rule book and follow the guidelines set down there.
    Littleman's suggestion of tacking it together and then taking it to someone who can weld it right is a great one. I built my T bucket by tacking pieces together and then taking them to a friend who was a highly skilled welder to have him to the finish welding on.
  24. rooman
    rooman
    Obviously not really "pro built" if the cages snapped at the welds. A poorly welded mild steel car will break too and as I noted earlier I see a lot of them in my business. Race cars (or street rods for that matter) are not the place to practice your welding. I am with Littleman on this one too--if you are not a weldor find someone who is, and not just the guy down the street that has a 110 flux core rig.
    As for the TIG vs MIG argument, if you use 4130 and want to run at NHRA events listen to HemiRambler, it needs to be TIG welded as per their rule book.
    Roo
  25. kelzweld
    kelzweld
    That there is good advice. Have done it for more than a few people. You don't pay for the fab, which tends to be the time consuming part, and you get quality welds. You do have to be able to fit things up well though. And on the 1018 vs 1020, I'd use either but would prefer 1020 if both were availiable. 1010-1015 is furniture tube.
  26. bobw
    bobw
    From my 2008 NHRA rulebook: 4:11 Roll Cage
    "All 4130 chromoly tube welding must be done by approved TIG helicarc process; mild steel tube welding must be approved MIG wire feed or TIG heliarc process."
    So it really doesn't matter if there are other ways to weld, if you want to pass NHRA tech you must adhere to the above processes.
  27. iagsxr
    iagsxr
    +1 Moly circle track chassis' are mig-ed all day, everyday.
    The issue as it applies to this discussion is that NHRA specifies tig only for moly.
  28. mr slingshot
    mr slingshot
    from Belgium
    If you build a FED what`s beter to drive 180"or a 200"
  29. rooman
    rooman
    Theoretically the longer wheelbase should make the car more stable but the design of the frame, engine placement etc all come into play.
    Roo
  30. Come on Alex,,I know you suffer from A.D.D. but what about the coupe? HRP
