Customs too low? 51-52 plymouth
Discussion in 'The Hokey Ass Message Board' started by impossie, Mar 22, 2010.
  1. impossie
    impossie
    from kentucky
    im trying to see what looks good for 4-door 1951 - 1952 plymouth cranbrooks... i read on here that the rear doesnt need to be c-notched. also, the front doesnt need much work lowering either.
    just wanted to see what people thought and maybe see some other pictures of 51-52 plymouths lowered.
  2. BEAR
    BEAR
    i say go lower lol looks good this low
  3. impossie
    impossie
    from kentucky
    "zues'" 1951 plymouth, airbags with no c-notch
  4. RalphyBoy161
    RalphyBoy161
    Low & Slow is what you want!
  5. impossie
    impossie
    from kentucky
    how many coils do you think i should/can cut to get that look? whats the max coils can i cut before i need to do anything else?
  6. need louvers ?
    need louvers ?
    The best way to do this is in stages. Take one coil off, then put it back together. Let it down and check. If it isn't low enough, repeat. Just don't go so low that you run out of suspension! Low is cool, but it sucks if it rides poorly.
  7. Jarzenhotrods
    Jarzenhotrods
    from .......
    I honestly dont think you will get it that low by cutting coils. Maybe if you take the entire coil out.. Just kidding dont do that. I have only seen cars this low on bags.
  8. impossie
    impossie
    from kentucky
    hah. true. steps are good. i think i read that 2 coils are the most i should go, even if i want lower. but ill try 1 then 1 1/2 then 2 if needed. the back i think 3 inch blocks are a must. i lucked out that the frame is some what "c-notched" stock. ill put up picks once im done with the whole process from spring cut, shock relocate, wide white, etc...
    p.s will the G78-15 COKER CLASSIC 2 3/4" Whitewall Tire fit under those wheel wells lowered????
  9. Midwest Rodder
    Midwest Rodder
    I think you need to go with bags if you want to get it that low.
  10. impossie
    impossie
    from kentucky
    does anyone have any lowered 51-52 plymouths pictures they like to share? maybe some info on some setups?
    thanks
  11. 6berry
    6berry
    is "too low" a legitimate sentence? i think u might need to check and make sure cuz that doesn't make sense to me
    iadubber likes this.
  12. One coil cut & blocks gets 'em lookin' nice. Done this way with lakes pipes, they look good. Lakes pipes look VERY good on these cars. Bags are the go for that 'on the ground' lifestyle.
    These are fine old cars so a fine way is reset springs and nice shocks so you can have fun driving it.
  13. impossie
    impossie
    from kentucky
  14. Thanks- i wiped it 'coz it hi-jacked the thread.
    Mate of mine had one of these cars, lowered mildly in black w/ lakes pipes, mostly stock, and he dug it as a cruiser. And this is a guy whose owned 200 + Fords!
  15. LOWLYDE
    LOWLYDE
    my old 50 ply i cut 2 1/2 coils BUT!!! i would cut a half at a time to be sure due to motor size and coil strength it could be way different :eek:(i would never recomend this):eek:i needed it low cheep and quick, so... the night before a show i flipped the rear springs:eek: ha ha what a dumb desion :D but it looked cool:D
  16. gaskell
    gaskell
    from CO
    Bag it... Then you can adjust it all you want... Plus that way you can get in and out of the driveway..
  17. LOWLYDE
    LOWLYDE
    Thats a true statement!!
  18. Lazer5000
    Lazer5000
    I love those cars. My first car was a 51 Cranbrook sedan. I would bag it. Especialy if you don't have to notch it. I just did my 46 ply coupe and it hits the ground without a notch. Check with Kustombuuiler here on the HAMB, he offers a great deal on air ride.
  19. Xtrom
    Xtrom
    from Forman, ND
    I put 3 inch blocks in the back of my 51 plymouth but had trouble with the driveshaft hitting the floor when you had anybody in the back seat. But the leafs might have been shot too. Just speaking from my personal experience. Ended up going down to 2 inch blocks and not putting too much weight in the back.
  20. Rickybop
    Rickybop
    "Too low" is a very legitimate phrase. Driving a car that's so low that any part of the car is below the scrub-line, is dangerous. Have a tire blowout at speed, and having your bumper or any part of your chassis make contact with the pavement, and you can hurt yourself and/or someone else. Of course, if you "bag it", and lift it to travel, you're safe.
  21. Wicked50
    Wicked50
    Put it on the floor
  22. davis574ord
    davis574ord
    Just lower the rear and see hoy you like that first!
  23. v8val
    v8val
    one coil equals 2 inches in these cars, so 1 and a half in front and 3 inch blocks in back is sweet. Any lower you'll need bags. can get 2 inch dropped uprights for the front too.
  24. flathead51
    flathead51
    from Tacoma
  25. rivguy
    rivguy
    Wow! never seen a cooler Plymouth.
  26. kustombypook
    kustombypook
    So what happens when a bag blows out or fails, then the scrub-line issue is a real problem?
  27. bobx
    bobx
    from Indiana
    i would say first you poop in your pants, then the scrub line thing comes into play.
    put together the right way though, bags rarely fail.
    im sure they do and have, but its not all that common. the scrub line should be taken into consideration though.
  28. slicknapier
    slicknapier
    from Tucson, AZ
    The driveline will definitely be an issue. I had dropped springs built for mine then added 3" blocks and the driveline would hit the floor. I have one coil cut in the front and if if you hit a dip going fast enough the front coil compresses to much and bottoms out. Also, I have G78-15's and they will hit the body once you get low enough. Here are some pics of my 51 Business coupe. The first ones are with the leafs and blocks. I am in the process of bagging and 4 linking it!
  29. domepiece
    domepiece
    Up front you can also move the lower spring perch from the top of the lower a-arm to the bottom of it. should get you about 1.5 to 2 inches lower.
  30. Ace50coupe
    Ace50coupe
    from Indiana
    well its all about bags bitches and body drops. First chopping the springs to get it that low you would not want to consider. Even taking a half coil out will give you aloy of negative camber. The back you could do drop block and de arch the springsbut even then your handling would turn to shit. The front could be done with spindles but that can be pricey. best way would be new front clip and four link the rear for some bags. Although if you want to leave it a static drop drop blocks in the back spindles up front and channel the car will get you there maybe not laying the rockers but atleast closer to the ground. Also to do this you would have to c notch the rear and raise the drive shaft tunnel. Even z ing the front or rear of the frame is possible
