Technical Too low of vacumn to modulator valve ?
Discussion in 'The Hokey Ass Message Board' started by junkyardjeff, Nov 29, 2020.
  1. Mimilan
    Mimilan
    How much distance between your modulator vacuum source and your PCV vacuum source.
    The PCV will flow volume, whereas the Modulator only needs Vacuuum [negative pressure]
    The Modulator source should be on a manifold runner . If you did it the other way round and hooked up the PCV to a manifold runner, it would be enough to lean out some cylinders [a controlled vacuum leak]
    Your vacuum could be great at idle, but when driving down the road the PCV could be reducing the vacuum to the modulator
  2. junkyardjeff
    junkyardjeff
    PCV is coming from the big port on the Holley 4 bbl and the modulator is hooked to the port on the carb spacer. When I adder power brakes the only port left I think is on a intake runner so it looks like I will have to re plumb the booster and modulator.
  3. Budget36
    Budget36
    Before the rebuild, try cleaning up the valve body as was suggested before...little time, little fluid, a gasket (maybe a mess) but it's what I would do with the advice offered before.
  4. Mimilan
    Mimilan
    The port on the carb usually plumbs into the centre so that all 4 throats are equal, and you don't have a leaning out on 1 side situation.
    Your modulator is effectively plumbed underneath the PVC so it would see a vacuum drop.
    Try a temporary hook up to where the brake booster goes. [even if it means disconnecting the booster it to see if it works]
    On a '66 mustang C4 the modulator is connected to a manifold runner [behind a carb] tee'd with the booster
    Both the booster and the modulator require vacuum, not flow .
    I hope it is as simple as this for you!
  5. Charlietruck62
    Charlietruck62
    Do this. All Ford modulators are hooked to a manifold runner vacuum source.
  6. junkyardjeff
    junkyardjeff
    PCV and booster are hooked to where they get vacumn from all 8 and the modulator is on a runner,I changed this before I fired it up and the initial third gear shift still did not happen until around 45 then it started shifting normally. Put some of that Trans X stuff in it and let it go through all the gears and will see how it does tomorrow. Going to adjust the bands before firing it up tomorrow,if I can get it to start acting normal I start on getting the Y block and COM ready to install. I really do not want to rebuild the C-4 and then shortly after get the 62 COM gone through.
