Took wattzit? "Hammer" wrench?
Discussion in 'The Hokey Ass Message Board' started by Brad54, Jul 19, 2011.
  1. Brad54
    Brad54
    from Atl Ga
    I picked this up over the weekend, at a stash of Model T, Model A and '20s Chevy parts.
    I thought it was an axle nut wrench, but there were a couple Ford banjos there, and it didn't fit the nut on them.
    It is 1 1/8-inches across the flats, which was bigger than the axle nut.
    Anyone know what it fits?
    Its steel, has no markings, and doesn't appear to have ever been hit on the ends.
    -Brad
  2. squirrel
    for a single cylinder engine flywheel nut?
  3. Lotek_Racing
    Lotek_Racing
    It's the dogbone from a drum puller.
    The puller has three legs that fit over the wheel studs, three lug nuts go on, you run the forcing screw down against the axle end, put the dogbone over the hex on the end of the forcing screw and bonk the end of the bone with a hammer in a clockwise direction and it separates the hub from the axleshaft.
    See? [​IMG]
    Good for old two-piece semi-floating axles like the Jeep and IHC used to use.
    Shawn
  4. RoadsterRod1930
    RoadsterRod1930
    from NEPA
    no thats for the end of a drum pulling tool, made that way to hit on either end of it
  5. PBRmeASAP
    PBRmeASAP
    ok, what's ya got for 20's chevy stuff...
  6. Yup, puller................if you got the rest of it you scored!
