Tool idea- powering a bead roller.
Discussion in 'The Hokey Ass Message Board' started by fbama73, Mar 23, 2010.
  1. And we wonder why their are all the OSHA and other safety features making most tools more unsafe. :mad: if you are not coordinated enough or scared of something leave it alone! mother nature has a way of eliminating the lame ones.;)
  2. Stevie Nash
    Stevie Nash
    She's got a way of eliminating the not so lame ones too... :cool:
  3. Never2old
    Never2old
    from so cal
    Since it's direct, drive I'm curious about how far it runs on after the power is off.
    All the gear motors I have seen run on for a little while, depending on the load.
  4. You are more likely to die driving your car than building it.
  5. sawzall
    sawzall
    dont have photos right now.. but I am powering my harbor freight bead roller with a harbor freight electric winch...
  6. FiddyFour
    FiddyFour
    i dont think a sewing machine motor is going to have to torque to go the distance...
  7. wanabe28
    wanabe28
    Maybe i should wear pants while working on my car?:eek:
  8. 60 GASSER
    60 GASSER
    oh it does and will you gotta gear it down a bit and i've seen window motors used also!
  9. FiddyFour
    FiddyFour
    pants? **** that means i need to wear underoos too.
  10. bonez
    bonez
    from Slow lane
    you funny fugger! i wanted to be the one to tell him :D
  11. FiddyFour
    FiddyFour
    i didnt "power" mine, but i did make it easier to work with one hand and also be closer to the business end of the roller as well...
    here is a "tech" i did a few years ago here on the board showing how i beefed mine up and added the horizontal wheel to turn the roller. the wheel is a little different now, and i've cleaned the frame up some since also, but it gives an idea at any rate.
  12. Jim Stabe
    Jim Stabe
    I used a12v HF winch (powered by a jump start pack) and mounted the 1 1/4" bore sprocket on the cable spool after turning the diameter down slightly. The disengage feature is handy if you come up to a tight corner, you can just let it freewheel and turn it with a handwheel. I welded a 3/4" socket to an old steering wheel that slips over a 3/4" hex bolted to the lower shaft. The hand controls converts easily to a foot pedal, picture isn't mine but looks exactly the same.
  13. 22george
    22george
    from ohio
    I just powered one using a 1/2 in reversible air drill and 2 ford flex plates and 2 starter gears to slow it down. Used a foot pedal from a harbor freight planishing hammer to start and stop
