Projects Tools
Discussion in 'The Hokey Ass Message Board' started by John "Gunner" Gunnell, Oct 7, 2010.
  1. 39 Ford
    39 Ford
    My list will contain lots of things that others have listed but here is my personal favorites.
    Vice and workbench
    Drill Press floor mounted
    Power Hacksaw
    Bench grinder with one side equipped with a wire wheel
    Air Compressor
    Air tools
    4-1/2 "hand grinder I have several one with a grinding wheel and one with a wire wheel
    7" hand grinder
    7" skill saw with metal cutting blade
    floor jacks
    jack stands
    drop lights and good shop lights
    Exhaust fan
    Mig welder
    Ox Ac setup
    Antique stick welder ( all I ever used for years)
    In the movie GrandTorino the kid asks Clint Eastwood how he got all those tools and was told over a lifetime, how true.
  2. krackerjack88
    krackerjack88
    from Fresno,Ca
    Love the metal flake, Bad *** idea!
  3. dawford
    dawford
    After a quick overview I didn't see one of my favorites.
    A high pressure power washer sand blaster attachment.
    I have cleaned up Model A frames and boat trailers in less than an hour using a good pressure washer and a sand blasting attachment.
    The first pressure washer was a 6hp gas driven machine and it worked ok but slow.
    The second was a 9hp unit that worked better but the 13hp unit I now use works very well.
    I just hook it up to the water hose, attach the blaster and put the sand pickup in a bucket of dry sand and blast away.
    The water does its job just like it should but the sand takes it down to good paint or the metal depending on what you want.
    The beauty of the thing is that you only need eye protection because the water keeps the rebound and the dust under control.
    If you are a worrier you could use a mask but I havent found that I ingest anything that I can detect.
    I just do the work out in the open on a pallet and let the sand go where it wants.
    A couple of $5.00 bags of sand will do a frame.
    If I lived in the city I would put up a tarp to trap the sand and maybe use a kiddie pool to allow the sand to sink and the water to run off.
    The sand could be dried, sifted and used again.
    I purchased my attachment from Northern tools.
  4. Flying A
    Flying A
    It seems as though I have a good representation of all the tools my hot rodder peers have. However, I use a few other things that are more custom made than purchased.
    Custom metal chop sticks (strips) for several rivet hole sizes for locating panel rivet holes.
    Crazy custom fabricated combinations of press tools to press items together or apart.
    Custom fabricated special fork tool to set the brake proportioning valve while bleeding the brakes.
    Home made nine inch Ford housing jig from an old hog head with centering bearing plugs for long alignment shaft, long alignment shaft and two flange end center locators.
    Shop couch from an old van equiped with arm rests and seat belts for cigar and beer breaks.
  5. Flying A
    Flying A
    It seems as though I have a good representation of all the tools my hot rodder peers have. However, I use a few other things that are more custom made than purchased. :)
  6. TagMan
    TagMan
    1. Lathe
    2. Drill press
    3. Engine hoist
    4. Sawzall
    5. Car lift
    6. Cut off saw
    7. The common, bench mounted vise
    8. Band saw
    9. Mill
    10. Welder
    11. Angle grinder
    12. Press
    13. Acetylene torches
    14. Air compressor
    15. Sandblasting cabinet
    16. Pedestal grinder
  7. 48cad
    48cad
    Your right, cant build a car without Sharpies. From my experience it takes about 36 Sharpies per car. I don't know what happens to them.
  8. 76cam
    76cam
    Hammer
    Screwdriver
    Torch
    Pry Bar
    Tape Measure
    Bigger Hammer
    Dolly Set
    Welder
    A good 1/2inch
    And a good 9/16ths
    Speed Wrench
    Beer
    2 Friends
    Good eyes
    And hope it turns out the way you want it too.
