Hot Rods toothless flathead flywheel
Discussion in 'The Hokey Ass Message Board' started by drumyn29, May 8, 2026.
  1. drumyn29
    drumyn29
    What do you guys do about a flywheel that sounds like grinding metal while starting it. I'm in L.A.
  2. Doublepumper
    Doublepumper
    from OR-WA, USA
    I usually check the ring gear and starter pinion for damage. I'm not in L.A.
    :rolleyes:
    alanp561 likes this.
  3. drumyn29
    drumyn29
    The starter actually looks near perfect!
  4. 1biggun
    1biggun
    Look at the ring gear for one .
  5. I’d dig another FW out of my parts pile
    Tow Truck Tom likes this.
  6. drumyn29
    drumyn29
  7. Wanderlust
    Wanderlust
    Starter needs the correct bolts to locate, regular bolts don’t have the shoulder, may also need the front strap as well
    Petejoe likes this.
  8. F-ONE
    F-ONE
    from Alabama
    Correct starter plate?
  9. alchemy
    alchemy
    He’s got an early flathead, so no starter plate to be wrong.
    F-ONE likes this.
  10. drumyn29
    drumyn29
  11. Wanderlust
    Wanderlust
    Well you’re ring gear is done, you could flip it and get a “little “ more out of it;)
    19Eddy30 likes this.
  12. drumyn29
    drumyn29
    I LIKE THE WAY YOU THINK!!!
    Wanderlust likes this.
  13. drumyn29
    drumyn29
    Do shops still install ring gears? Are they available or is it better to find a good used one?
  14. Wanderlust
    Wanderlust
    Probably just as easy to do a search for a good used flywheel
  15. rusty valley
    rusty valley
    just buy a new ring gear. they are not that expensive, and easy to put on. got a torch?
    210superair and 19Eddy30 like this.
  16. Jagmech
    Jagmech
    Put new ring in oven.
  17. drumyn29
    drumyn29
    I got a torch! Press on? Hammer on?
  18. drumyn29
    drumyn29
    Remove old with heat? Install with heat?
  19. Moriarity
    Moriarity
    SUPER MODERATOR
  20. A tutorial and a safety video all in one. Thanks @Moriarity
    Moriarity and Tow Truck Tom like this.
  21. 51504bat
    51504bat
    When I installed a new ring gear on the flywheel for my 8ba I cut the old one off with a cut off wheel (partially thru and then banged it off with a BMFH and chisel. Heated the new ring gear on the barbie and put the flywheel in the freezer. Just make sure you place the teeth facing the right way. Flathead starters engage from the rear not the front.
    19Eddy30 and Jagmech like this.
  22. woodiewagon46
    woodiewagon46
    from New York
    Don't flip the ring gear, it's too big a job to have to do it again!
  23. drumyn29
    drumyn29
    Ok, since I have everyones attention, next question. On a 30 ford coupe hot rod of the early era, obviously a 36 ford rear is narrow and perfect but is it a HUGE difference compared to a 40 mercury rear or a 40 ford rear?
  24. alchemy
    alchemy
    36 is same width as 40 Ford. Not sure about Mercury.
  25. rusty valley
    rusty valley
    Like in the video, just heat until it falls off. This is especially important on a flathead flywheel because they have a very thin ring on the flywheel to help locate the ring gear. you must heat until it falls off, do not attack with a hammer or you will break off the paper thin ring. Like this...in yellow C5F69AC0-9DD1-46C5-893A-059039E11C21.jpeg
    big duece and Algoma56 like this.
  26. drumyn29
    drumyn29
    Thank you
  27. drumyn29
    drumyn29
    And for a front axle, any year from 32 to 48 car?
  28. RICH B
    RICH B
    '32-'36 axle, '37-'48 spindles
    rusty valley likes this.
  29. drumyn29
    drumyn29
    Thank you
  30. big duece
    big duece
    from kansas
    I ordered one from Dennis Carpenter, and its a wall hanger now. Some one ground the piss out of the ID probably to try to make it fit, and returned it. Ended up getting shipped to me... the dissapointing part was I had to argue for a bit with them to get a refund. I found an original in good shape. A new starter ring laid over a fire pit supported with a couple peices of rebar to suspend it should warm it up. Grab it with some leather welding gloves and get it on quickly, let it cool. You can see the original ring size, below the aftermarket one.
