1952-59 Ford top chop
Discussion in 'Off Topic Hot Rods & Customs' started by 56FORD390, Apr 1, 2018.
  1. 56FORD390
    56FORD390
    Unrelated to anything I am planning, but how does one cut the windshield and rear windows to match the chopped top?
  2. Skeetum
    Skeetum
    The windshields can be cut, very carefully. There are several ways to do it. Traditionally with a standard gl*** cutter, then lighter fluid to burn off the middle membrane of the laminated gl***. The rear gl*** can't be cut, because it is tempered gl***. With the rear window you have 3 options; lay the gl*** down forward to achieve the lowered look, lower the gl*** into a channel below the trunk line - similar to how some cars windshield wipers rest below the hood, or use plexigl***. Note that I am not an expert, this is the info I found out when researching the chop on my '54.
  3. okiedokie
    okiedokie
    from Ok
    Have a friend who bought a chopped 57 sedan delivery. Windshield was cracked, but came with new one to have cut. After the third cracked windshield, he sold it with a new replaceacement. All three were cut by different gl*** guys. The final cut was made to fit a pattern made from the opening, still cracked after a couple of hundred miles.
  4. 56FORD390
    56FORD390
    okiedokie, do you happen to have a photo of the chopped sedan delivery?
  5. green53ford
    green53ford
    from Wisconsin
    Cut the gl*** first. You can make the metal fit the gl*** but you cant bend the gl*** to fit the metal.
  6. okiedokie
    okiedokie
    from Ok
    Sorry I don't, but it was a Chevy.
  7. guthriesmith
    guthriesmith
    Hmm...was the sedan delivery a 57 Chevy? I may know where it is now.
