Technical Top chop
Discussion in 'Traditional Hot Rods' started by David Knapp, Feb 4, 2015.
  1. David Knapp
    David Knapp
    Looking to lower the top on my 31 sedan ,would any have a ball park figure what is might cost to have this done ?Looking about 2 1/2 ".
    Anyone in the lone star state can do this job ?
  2. aaggie
    aaggie
    I think 4" looks good on Model As. There are several places that do tops, in the Houston area try Bruce's Rod Shop in Klein. In Austin try Austin Speed Shop. As far as cost goes it can vary a lot depending on the level of finish you want. Good luck.
  3. I cut my '30, 4" and it is very easy to do. If you can weld at all try it yourself, just measure alot before you cut and take your time.
  4. Get ahold of Dreddybear here on the HAMB if he won't do it he will know someone who will.
  5. wbrw32
    wbrw32
    Contact Rusty here on the HAMB,,,his shop is in Combine,Tex,,SE of Dallas just a liitle ways
  6. CrazyVern
    CrazyVern
    Get ahold of Jorel at Shockley Kustoms. It is in Denton, which is near by, does great work and is a good guy.
  7. David Knapp
    David Knapp
    Thanks for all input I'll look these guys up.
