Top Shift Toploader 3.03 Ford 3 Speed ?
Discussion in 'The Hokey Ass Message Board' started by Toymaker, Jun 15, 2008.
  1. Toymaker
    Toymaker
    from Fresno,CA
    I've done a search on installing a "Top Shifter" on a "Toploader" Ford 3 speed 3.03 transmission and have only found 4 speed info using the Jeep shifter. Anyone know if this conversion is possible and what parts are required? Thanx in advance, Rocky
  2. Relic Stew
    Relic Stew
    from Wisconsin
    Jeeps also had a 3 speed with the top shifter. Conversion should be similar to the 4 speed setup. The T-150 was the 3 speed used 76-79, and the T-176, 177, and 178 were the 4 speeds used 80 to 86.
  3. Jimmy2car
    Jimmy2car
    from No. Cal
    Check here: http://www.modelaonly.com/about_us. This guy is in Norcal and uses the Ford F-150 trans from a six cylinder, I think. Don't know what you're after, but this might be it.
    Regards
    Jim
  4. Jimmy2car
    Jimmy2car
    from No. Cal
    Forgot to add.. If you're going to adapt to a Flathead, contact Gene Sanders, at M.E.C. He manufactures a really nice adapter for this application, or you can use a truck bellhousing.
    Jim
  5. Jimmy2car
    Jimmy2car
    from No. Cal
  6. Pierre H
    Pierre H
    from france
    just find a T150 shifter, it's almost plug and play, find mine on egay for $30
    Sixhundred sixteen likes this.
  7. Toymaker
    Toymaker
    from Fresno,CA
    Got it, T150! Thank You
  8. RichFox
    RichFox
    I thought it was the trans that came in the CJ5. If that helps?
  9. Flat Ernie
    Flat Ernie
    Tech Editor
  10. Koz
    Koz
    Toymaker, I ran a thread on this about two weeks ago under BorgWarner T-15 with Jeep Shifter. Lots of good info there.
  11. Flat Ernie
    Flat Ernie
    Tech Editor
    That's the thread I linked...:rolleyes:
  12. Toymaker
    Toymaker
    from Fresno,CA
    Great info, Thanx again guys!
