Ok- I just picked up a toploader for use behind a 460 in my next project. The trans is a 428 unit out of a torino. On a small-shaft toploader, the 390 input shaft is shorter than the 289/302/351 input shaft. Is the 428 1 3/8" input shaft the same length as a 429 1 3/8" input shaft? The 460 currently has a TKO behind it, and it's still in the car so I can't compare the two... Thanks for any help!
Try these guys . Great bunch and you will find the answer . http://www.460ford.com/forum/ http://www.429-460.com/ These are the best groups around for BBF information . Jim
