1952-59 Ford Torino, power steering.?????
Discussion in 'Off Topic Hot Rods & Customs' started by rockin rebel, Apr 15, 2012.
  1. rockin rebel
    rockin rebel
    ok, I got my 72 Torino parts car today.. you guys say the disc brakes are same as Granada. and I can use the 9" rearend. how about the power steering box..?? not power ***ist, but box..? thanks, Lloyd
  2. old lady's mad
    old lady's mad
    ok, if your 54? has ball joint instead of king pins. the spindles will work with a little modification. the bottom ball joint hole is to big. it will either need a thin shim put in the taperd hole, or grind/mill the bottom of the spindle off so the taperd pin gose up in far enough to tighten down properly. fist question is was it a big block car? if yes its a diffrent bolt pattern. its chevy truck pattern 5 on 5. the rearend might work if its the correct length. just have to cut the bat wings off and weld on spring perchs.
    p.s. gear? wont know till you try it.
  3. rockin rebel
    rockin rebel
    mine is a 53 ??
  4. old lady's mad
    old lady's mad
    isnt a 53 a king pin car? not ball joints.
  5. Mark T
    Mark T
    Ford didn't use ball joints until '54 so the Torino spindles wont work.
    I think the rear is go to be to long for the '53.
  6. rick55
    rick55
    I saw on eBay last night under "Ford y block" a 9" diff from a 1957, wasn't all that expensive for something, that, with a little work will slip straight in. The spring perches would need to be lined up to fit correctly. The diff was complete with brakes.
    Regards
  7. rockin rebel
    rockin rebel
    damm, I guess I was not paying attention....so the Granada ect., only fit 54 and up... ok I have a set for sale..lol
  8. Retro Jim
    Retro Jim
    Is the wheel base the same width as the truck or close ? Do some measuring and if the width is really close , then just do a frame clip and there you go . I know guys use S10 frame clips a lot for the trucks but I am not sure about the width of a Torino .
    Jim
  9. rockin rebel
    rockin rebel
    Hey Jim, I have that truck in my avtar, but also a 53 Ford 2 dr....
