Hot Rods Torque Converter Lockup Dash Switch
Discussion in 'The Hokey Ass Message Board' started by AngleGrinder, Aug 2, 2019.
  1. AngleGrinder
    AngleGrinder
    Good day ... Bought a Torque Converter lock up kit for a rebuilt 200 4R complete with a mechanical dash switch to lock up my torque converter in 4th.
    I want to use the existing brake pedal switch to kill the Torque Converter lock up when I hit my brakes.
    My question... Is there a dash switch that when power is cut (using brake pedal) that will reset the dash switch to off ? Thank you.
  2. Doublepumper
    Doublepumper
    from OR-WA, USA
    You could use a momentary switch on the dash to power a relay and use the stop switch to kill power to it. Wire it up so that switching on the relay with the momentary switch would latch the relay and energize the TC and stepping on the brakes kills control power to the relay and de-energizes the TC.
  3. AngleGrinder
    AngleGrinder
    Thank you Double P, was hoping an e switch on the dash could accomplish.
  4. Cosmo50
    Cosmo50
    6sally6 likes this.
  5. AngleGrinder
    AngleGrinder
    Double-P, I don't quite get that the momentary switch could activate the relay and it would stay activated even after the momentary switch would go back to off. I'm fogged up, sorry. Thanx so far Double P
  6. AngleGrinder
    AngleGrinder
    6sally6 and Cosmo50 like this.
  7. saltflats
    saltflats
    from Missouri
    Get a brake switch like this.
  8. AngleGrinder
    AngleGrinder
    Hey Dude, thanx, have to read up on it though cuzz its electronic, yuk.
  9. Mimilan
    Mimilan
    Very easy to do with a relay.
    You use a push ****on to activate the relay. (When released it is off)
    On the output side of the relay you run a wire around to the ****on side of the relay (This latches it to stay on after the ****on is released)
    Now this latching wire MUST be wired in series with the brake switch to break the circuit and switch it off.
    Use a GM brake switch with the cruise control feature.
  10. AngleGrinder
    AngleGrinder
    Thanx, do appreciate.
  11. Gman0046
    Gman0046
    On my 60 Pontiac I'm using a second floor mounted dimmer switch to lock up the 2004R torque convertor and a small light bulb on the bottom of the left dash in the vicinity of the parking brake release handle to remind me when the torque convertor is locked up. A safety item as I don't have to divert my eye balls from the road looking for a lock up switch
    saltflats likes this.
  12. Mimilan
    Mimilan
    Also if you want to be "creative" , you can add a GM vacuum switch between the output of the relay and the Torque Converter lockup.
    This way it will unlock on acceleration/kick down , but the relay still stays latched so it will re-engage lock-up when you lift off the gas.
    cheers Mimi
  13. blowby
    blowby
    from Nicasio Ca
    I have exactly the same thing.
    If I understand the original question, why would you want to turn off the lockup after tapping the brakes in OD? If I'm getting off the highway I just hit the switch and unlock, rather than having to constantly turn it back on.
  14. bowtie56jw
    bowtie56jw
    im running a gm vacuum switch and a toggle switch, i can leave the toggle on and when it shifts into 4th it locks up, let off the gas and it unlocks as it should. i can run with the switch off and no lock up but have all 4 gears. fun to play with.
  15. gimpyshotrods
    gimpyshotrods
    I generally set them up to run fully automated. Vacuum switch and brake light switch. At minimum, automatic lockup, in 4th, only.
    If a customer requests it, I put in a switch to disable the lockup, when desired.
    You will be hating life if you have a fully manual system, the first time you forget to unlock it, at an intersection. Your insurance company might have some questions that you don't want to answer. Answer those questions wrong, and you might see your policy voided.
  16. AngleGrinder
    AngleGrinder
    Thanx, appreciate
    Because I can't be trusted to "just hit the switch and unlock". I'd prefer use the lock up similar to a cruise control. Thank you, appreciate.
  17. AngleGrinder
    AngleGrinder
    This sounds good thanx appreciate.
  18. AngleGrinder
    AngleGrinder
    Good heads up, that's why I want the ****er off when I hit the brake pedal similar to cruise control. Appreciate the advise thanx.
