Technical Torque Converter Lockup
Discussion in 'Traditional Hot Rods' started by garychurchill, Mar 20, 2017.
  1. garychurchill
    garychurchill
  2. christmas tree
    christmas tree
    I have and it worked like a champ for me
  3. garychurchill
    garychurchill
    Cool, thanks for the reply! No issues at all? Still have the car?
  4. AngleDrive
    AngleDrive
    from Florida
    The problem with the one you want to use is when you shift into high gear it immediately locks up converter. I use the Ron Francis set up as it is adjustable and works like the factory set up. My clients love them.
    https://www.summitracing.com/parts/rfw-tc70
  5. garychurchill
    garychurchill
    AH that one probably won't work for me. I was planning on using a gps speedo. I currently don't have a speedo cable and wasn't really planning on adding one...
  6. David Gersic
    David Gersic
    from DeKalb, IL
    I'm just finishing installing TCI's version here. It's a wiring kit only, ***umes your trans has everything in it that's supposed to be there. Turns out mine had the wiring harness removed at some point in its life, cut off at the TCC lockup solenoid. Had to buy a new solenoid. Has a couple of wiring options, depending on how you want it to work. Wiring, vacuum, and external mounting of the vacuum switch are up to you.
    I looked at the Painless kit. Cost twice as much. Includes the solenoid. So in the end might have cost about the same. Seems more complete, though, including a firewall mounting bracket for the vacuum switch.
    Neither includes a power source or directions for one, which I thought was odd for Painless. TCI is a bit more DIY, so less surprising there. Painless is more inclusive, so I found it weird for their directions to end with "provide a fused power source".
  7. AngleDrive
    AngleDrive
    from Florida
    Dont need the cable, just the speedo gear bullet from trans.
    loudbang and blackbeard40 like this.
  8. Just add a toggle switch to the feed wire. Just use the l/u for actual highway driving, not around town.
  9. greg32
    greg32
    from Indiana
    As Mark said above. I run a lock up internal switch similar to what you have. Splice a switch in the 12V feed to trans. Works perfect. I usually don't use lock up until 55 or faster. It still unlocks by itself as you slow down. And run a good trans cooler.
  10. justpassinthru
    justpassinthru
    We use the TCC control from Bowler Transmission. Very simple to install. One wire hook up to the trans control module that you plug into the trans case connector and a TCC/brake switch. Applies TCC 8 seconds after 4th gear and will disengage when applying the brakes. No vacuum/electric switch or speedo needed. You do have to change the solenoid in the trans.
    Kit comes with everything needed and is around $190.00
    Bill
  11. garychurchill
    garychurchill
    I ended up ordering the Bowties Overdrives lockup controller. Thanks for the input guys!
  12. 325w
    325w
    Local trans guy will only do your 700r if you agree to use the Bow tie set up.
  13. Toqwik
    Toqwik
    I used the toggle switch mentioned above, worked great with no issues.
