Torque Converter Recommendations
Discussion in 'The Hokey Ass Message Board' started by Smokey Stover, Jul 11, 2007.
  1. Smokey Stover
    Smokey Stover
    from Upstate NY
    What brands do y'all recommend OR suggest I stay away from.
    Hughes Performance, TCI, B&M ???
    Trans is TH350, engine is a Pontiac making about 400 ft lbs starting at 2000 RPM in a fenderless '29 A Coupe.
    And yes, I know thats a lot of torque for a TH350 to digest but it's a light (~2500 lb) car.
    I used a 500 above stock convertor in my light weight (2000 lb) roadster and still had to keep my foot firmly on the brake at lights.
  2. DirtyThirty
    DirtyThirty
    from nowhere...
    I personally like to stay away from the ***embly line ones, like b&m and tci...I have a tci, 10" 3500 stall unit in my coupe right now, but the price was right, and It was laying around, so in it went, but, I have had problems with them before.... I like ATI...they will re-man it for you and change it, down the road if you want, without having to buy a whole new one...
  3. flamedabone
    flamedabone
    I have a guy in SC who builds all my converters. I would never run anything other than his, even on a mild application.
    He builds everything from mild mannered to full kill ***emblys like mine that take the torque of my blown Pontiac. My converter was custom built to my specs, full roller stuff, hardened everything, anti-balloon plate, yada, yada for under 500 bucks.
    He can probably whip you up a nice street converter for 2 bills, and have it to you inside of a week.
    Please do not buy a B&M, their inside hub comes to a small taper instead of a nice big surface which makes the front thrust wear quickly.
    Good luck and please post some pics of that Poncho motor!!
    -Abone.
    Torque Converter Services
    Coloumbia, South Carolina
    1 800 537 7416
    ask for Cameron
  4. D.W.
    D.W.
    from Austin Tx.
    Hey Abone. Ain'tchoogotta 4 speed in that nasty sedan?
    Cause if you've got an auto, I had better learn to shift:D
  5. bwiencek
    bwiencek
    GO with a higher stall than you're thinking of in a light car with a ton of torque - something in the 28-3K range..
    I've run an ATI and a TCI and both held up well. Heard bad things about the B&M's but never had any personal expierence with them....
    Abone - can your buddy do ford AOD converters? Going to need one for the '50 F2...
