Technical Torque converter weight
Discussion in 'Traditional Hot Rods' started by PeggySue, Mar 25, 2021.
  1. PeggySue
    PeggySue
    Installed new TCI 350 with torque converter. After 3 or 4 start ups I thought I spun a rod bearing. Come to find out the weight let loose on one end and was hitting bell housing. Has anyone weld them back when in the car, don't like having to pull transmission
    Elcohaulic likes this.
  2. wheeltramp brian
    wheeltramp brian
    I'd push or hammer it back in the same spot and weld it back in. Mark where the welds were and grind them off and weld them back on to the same size give or take
  3. Dan Hay
    Dan Hay
    ^ what he said sounds like a good plan.
    egads, Hnstray and PeggySue like this.
  4. PeggySue
    PeggySue
    The weight is still attached on one end.
    dana barlow likes this.
  5. saltflats
    saltflats
    from Missouri
    I have added them to converters that didn't have one. Just don't blow a hole through it when welding.
  6. PeggySue
    PeggySue
    Thanks will get the hammer out
  7. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Lucky it was the trailing end that came loose.
    seb fontana, PeggySue and Hnstray like this.
  8. TA DAD
    TA DAD
    from NC
    Is it a new TCI converter ?
  9. Ebbsspeed
    Ebbsspeed
    Make sure you connect your welder ground lead directly to the flex plate or the torque converter. You don't want welding current to p*** through any bearings.
    1971BB427 and PeggySue like this.
  10. PeggySue
    PeggySue
    Yep, had starter the car 3-4 time never been on the road.
  11. TA DAD
    TA DAD
    from NC
    I would want TCI to make it right, no telling how that would go.
  12. PeggySue
    PeggySue
    Called TCI , they said they would repair it , no charge if I send it back. How does one get the fluid drained from the converter so you can ship it?
  13. oldiron 440
    oldiron 440
    I've heard some not so good things about TCI lately.
  14. Ebbsspeed
    Ebbsspeed
    You can lay it down on it's flex plate side, stick a small hose in it and siphon out as much as you can. If it were me, I'd seal it up and ship it. Let them worry about draining it.
    PeggySue likes this.
  15. footbrake
    footbrake
    Send it back! If you touch it all warranty is off.
  16. PeggySue
    PeggySue
    Thanks
  17. PeggySue
    PeggySue
    It's off warranty, over 90 days. They said if I send receipt with, they will repair.
  18. PeggySue
    PeggySue
    Called TCI again, year warranty, Jegs where I bought was 90 day, so good to go
  19. 1971BB427
    1971BB427
    from Oregon
    Just get a good heavy plastic bag and tape it up good to contain any fluid left inside. If it happened to leak out the shipper might stop the shipment.
    Johnny Gee likes this.
