Technical Torque tube drive shaft
Discussion in 'The Hokey Ass Message Board' started by 1946caddy, Apr 18, 2025.
  1. 1946caddy
    1946caddy
    from washington
    I'm getting ready to shorten the torque tube on my Model A. I'm not going to bore you with the specifics of the build but what I would like to know how much end play should be on the drive shaft after I cut it. There would be no reason for the splines if it didn't move back and forth a little bit. I'm talking drive shaft , not the torque tube.
  2. alchemy
    alchemy
    None. There are pins that go through the coupler holding the shaft to the pinion.
  3. Andy
    Andy
    The snap ring position for the bearing/speedometer gear is critical. I measured few rear ends and settled with .080 clearance. The driveshaft is pinned if 33 up and tapered if 28-32. Either way the driveshaft does not move relative to the rear end.
  4. rusty valley
    rusty valley
    Not very scientific, but here's how I've always done it. If you look at the front end of the shaft, the splines have a beveled end, about an 1/8". Now look at a shaft in a torque tube, set a straight edge across the bell and you will see that 1/8" bevel is whats longer than the tube. theres your length.
    seb fontana and alchemy like this.
  5. 1946caddy
    1946caddy
    from washington
    I know that on the pinion shaft at the rear end but where it goes into the u joint on the ******, it can't be too long or it would bottom out.
    I guess I should of said it's going onto a 40 pinion shaft at the rear.
  6. Andy
    Andy
    The only thing you should worry about is the position the bearing and speedo gear. If they are in the right place, you have no problem about the length of engagement in the U-joint.
  7. 1946caddy
    1946caddy
    from washington
    OK, I get it. Thanks for all the responses.
