Torque tube follow up - chopping the driveshaft.
Discussion in 'The Hokey Ass Message Board' started by Kevin Lee, Oct 23, 2011.
  1. Kevin Lee
    Kevin Lee
    Super Moderator
    Last piece of tech was chopping the torque tube.
    Here's the next step - I'm using a solid driveshaft since that's what most everyone has access to.
    There may be several "better" ways of doing this but what I'm trying to demonstrate are good results with common tools and a little forethought.
    First, dig out that slice of torque tube you removed and take the same amount from the driveshaft. Cutoff wheel in an angle grinder or for the insane person, a hacksaw. Wrap something around the open bearings at the banjo to keep debris out.
  2. Kevin Lee
    Kevin Lee
    Super Moderator
    DEEP chamfer (nearly to a point), a long piece of thick angle iron, and lots of clamps.
  3. Kevin Lee
    Kevin Lee
    Super Moderator
    Several p***es, rotating, re-clamping, more p***es. Stop just short of having anything proud of the driveshaft diameter.
  4. Kevin Lee
    Kevin Lee
    Super Moderator
    Rifle drilled chunk of thick walled DOM tubing. This should be a tight slip fit over the driveshaft and long enough to cause issues if you're trying to slide it over a poorly welded (read crooked) shaft. But if you took your time with the last bit you'll be fine.
  5. Kevin Lee
    Kevin Lee
    Super Moderator
    In place.
  6. Kevin Lee
    Kevin Lee
    Super Moderator
    And welded up. This may LOOK gnarly as hell to some once it's welded but it is strong and most importantly STRAIGHT.
    Everything slid into place as easily as it did when it was unmodified. Dropped a new gasket in place and it's ready to be cleaned up for paint and go back under the '29 roadster.
    Corsa likes this.
  7. sodbuster
    sodbuster
    from Kansas
