Technical Torque Tube Question
Discussion in 'Traditional Hot Rods' started by Bob Bagley, Apr 22, 2021.
  1. Bob Bagley
    Bob Bagley
    We all know that rear transmission yokes slip in and our to compensate for rear housing movement, how did these issues work with torque tubes? Thanks.
  2. They pivot on the back of the transmission, they dont have slip yokes. The rules for open drivelines don't apply to torque tubes.
  3. oldtom69
    oldtom69
    from grandin nd
    Chevy torque tubes DO have a slip joint on the front-needed for parallel rear leaf spring set up.Ford doesn't,think of the torque tube as one long suspention link
    grumpy gaby 2 likes this.
  4. squirrel
    the complicated Chevy torque tube, and it's splines, etc.
  5. alchemy
    alchemy
    The exact center of the Ujoint is the exact center of the torquetube ball, so they have the same pivot point. The Ford rearend rotates from that point.
    Since Chevys move in a different arc due to the parallel leaf springs, they need the slip splines to allow the rearend to be free from the transmission.
  6. Bob Bagley
    Bob Bagley
    Thanks, I was just curious
