Technical torque tube question
Discussion in 'Traditional Hot Rods' started by gdrummer, Oct 7, 2024.
  1. gdrummer
    gdrummer
    hey ya'll'
    working on my 37 ford panel, 59AB and 39 style trans.
    trying to get to the clutch so i need to pull the rear. trouble i'm having is separating the trans from the torque tube. i have enclosed a couple pictures. my question is where does it come apart and how much force is generally necessary? any tips? it really seems stuck in there.
    i'm still pretty new to the hobbie so i'd appreacite any info
  2. 62pan
    62pan
    Looks like your almost there. If you push the inner piece toward the trans I think you will find it's the u joint that is stuck.
  3. Budget36
    Budget36
    Is the rear spring still all attached?
  4. Doublepumper
    Doublepumper
    from OR-WA, USA
    Might try getting the torque tube as parallel to the trans angle as possible.
  5. 19Fordy
    19Fordy
    There are 2 ways to remove the transmission. One is to first remove the engine and keep the complete rear end in place.. The 2nd is to leave the engine in place and roll the rear end back. Reading this thread will tell you all about each. While you have everything apart, be sure to install all new torque tube clam shell seals. Go over to www.fordbarn.com and type in your question as they have plenty of info.
    39 Ford/Mercury transmission Removal - The Ford Barn
    Also, read the info. here:
    how to remove 1939 ford transmission - Search (bing.com)
    TagMan likes this.
  6. gdrummer
    gdrummer
    ok thanks for all the info. i have it out now i can't get it back in!
