Technical Torque Tube & U-Joint Differences
Discussion in 'Traditional Hot Rods' started by scoob_daddy, Oct 27, 2024.
  1. scoob_daddy
    scoob_daddy
    from Georgia
    Howdy all,
    I am in the process of converting a LaSalle transmission to closed driveline with a ‘42-48 Ford rear mount.
    On to my question.
    Are there any differences in U-Joints from ‘37-48?
    Are there any differences in torque tube & rear mount coupling fit ‘37-48?
    For instance, can I fit a ‘40 torque tube to a ‘42-48 rear mount? Is the “ball and socket” of the coupling the same dimensionally? If not, what years jive with one another?
  2. dwollam
    dwollam
    '28-'48 is the same ujoint. the bell on the torque tube is the same also although the clam shells are 4 bolt vs 6 bolt.
    They will all fit up at the trans.
    Dave
    jet996 and seb fontana like this.
  3. scoob_daddy
    scoob_daddy
    from Georgia
    Perfect, that’s exactly the info I’m needing! Thanks a ton!
