Hot Rods Torque wrench
Discussion in 'The Hokey Ass Message Board' started by Donald N Wemple Jr., Dec 14, 2022.
  1. Harv
    Harv
    from Sydney
    Is a torque multiplier a fancy name for a 6' length of water pipe :D?
    Cheers,
    Harv
    Boneyard51 likes this.
  2. Proto makes nice torque wrenches
    i was told proto is what gm factory workers as well as the usa and cdn military use.
    I bought the set of three in
    1/4” 3/8” and 1/2” drives that gets me from finger tight up to 250ft lbs
    proto and MAC tools are under the same umbrella (along with stanley)
    but i didnt like the style or design of any of the mac t/w i looked at at the time. if i recall proto is all USA made
    Boneyard51 and Truckdoctor Andy like this.
  3. old chevy
    old chevy
    Have been using torque wrench for years. Have used them to tighten everything due to my training with other hobby. Aircraft are very specific that way. No more snapped bolts or having something coming loose. Have the standard 1/4" 3/8" and 1/2" for daily use. Go get the 3/4" for the serious stuff. Just my habits sorry but it works Ed
  4. You haven’t lived until you torque 1” Mack U-Bolts! A torque multiplier is mandatory.
  5. bobss396
    bobss396
    The shop who does my inspections and oil changes on my OT cars uses torque-sticks when they put wheels back on. STILL.. they are tight as a water snake's *** if I have to take one off at home. I'll torque them these days to around 100 ft/lbs after finding a loose wheel on my old Ford.
    egads likes this.
  6. O.K. Jury is in. Picked up the car today and yes wheel lugs have to be set at 150 ft./lbs. Our mechanic said he always checks lugs when a car comes in for any type of service on the lift with modern Alloy wheels. He said for us to check them about every 3000 miles to be sure. We trust him. So there you go. Thanks for all the replies on this. An old dog learned a new trick.
  7. Stock Racer
    Stock Racer
    Started to doubt my 30 year old Snap-on click type. Spent $100 to have it checked. At 100 ft lbs it was within 1 lb right hand and within 3 lbs left hand. Interestingly enough I've never torqued anything left hand and never use it to loosen bolts. You get what you pay for so buy a good one.
    Yes, I do torque lug nuts.
  8. jerry rigged
    jerry rigged
    I used to work in a dealership for a certain German motorcycle manufacturer. There was a torque spec for practically every fastener. Critical fasteners like head bolts would get a lower torque then so many degrees of rotation after that, sometimes in more than one p***. Think "40 Nm, then 90 degrees, then 90 degrees again". We had extensions with little degree wheels on them.
