torsion bar spring rate ?
Discussion in 'The Hokey Ass Message Board' started by ago, Nov 5, 2012.
  1. ago
    ago
    from pgh. pa.
    I want to fit torsion bars to the rear of my 32 Ford. The rear weight is 1485 lbs. What spring rate would I need to support this weight?
    I know the arm length and bar dia. calculations, I need the total at the end of the bar.
    Ago
  2. Ned Ludd
    Ned Ludd
    150lb/in.
    That will give you a resonant frequency of slightly over 1.4Hz.
    This is ***uming that the figure of 1485lbs is ready to roll, with fuel, a bit of luggage, a p***enger, and yourself on board.
  3. lionsgarage
    lionsgarage
    from Washington
    I would love to see the calculations needed for this.....seems there wasn't enough info in the request too.
    Thanks, knowledge is king!
  4. ago
    ago
    from pgh. pa.
    Thanks Ned, that is what I had in mind. Winters performance and Schroder website should help with calculations. Might have to go with Midget race car torsion bars.
    Ago
  5. Andy
    Andy
    You don't include the weight of the rear end,wheels,shocks,etc in the weight used for the calculations. All of that is resting on the ground. Your weight seems very high as is. I would ***ume about 700 lbs sprung weight. I run 80 lbs wheel rate on my roadster.
  6. the size of the bar(length and diameter) depends on the length of the arm how close it's mounted to the wheel and how high it's mounted in the frame
  7. Ned Ludd
    Ned Ludd
    That is very true. I'd forgotten about that.
    If we thus subtract some for unsprung m***, and add some for p***engers, fuel, etc., let's say the in-use sprung m*** works out to 1200lbs.
    The spring rate should be 120lb/in for a resonant frequency of 1.4Hz.
    The formula is:
    K = M x f² / 9.7969, where​
    K = spring rate in lb/in
    M = sprung m*** in lbs
    f = resonant frequency in Hz
