Art & Inspiration Torsion bars
Discussion in 'The Hokey Ass Message Board' started by CustomJ, Jan 12, 2018.
  1. CustomJ
    CustomJ
    Can I put the torsion bar below the axel?
  2. zorro4153
    zorro4153
    from Pa
    20170226_131111.jpg 20170226_131158.jpg Not sure if you asking about front or rear axle. I don't think it would work on the front , but it works on the rear.
    Pics of how we did my ch***is ,
    hope it helps
    CustomJ, 54reno and mgtstumpy like this.
  3. gimpyshotrods
    gimpyshotrods
    If you mean that silver thing, with the two arms, underneath the plywood buck that your nose will be made on, then you might be talking about an anti-sway-bar, a relational spring between differing ends of the axle, that travels through mounts, or a tube in the ch***is, but is not locked to the ch***is.
    If it is locked to the ch***is, then yes, it's a torsion bar.
    In either case, it can go under, or over.
  4. Rootie Kazoootie
    Rootie Kazoootie
    from Colorado
    Torsion bars are pretty stupid they really don't know or care where they are mounted.
    CustomJ, deucemac, mgtstumpy and 3 others like this.
  5. oldtom69
    oldtom69
    from grandin nd
    nice set up-are you sure your'e not an old sprint car racer?
    CustomJ likes this.
  6. wrenchbender
    wrenchbender
    If you are talking about a suspension torsion bar yes it can be over or under the one thing to be certain of is making sure the direction is correct some torsion bars are left and right that refers to the direction of twist of the bar that is allowed if it is wrong it will break I have used torsion bars on my model t for 25 years and they work great I have however seen on a Chrysler car that had two left bars installed and the one on the right broke it was not my car and it was a OT car you have a pretty *****in car in the works I'd like to see more
    CustomJ likes this.
  7. CustomJ
    CustomJ
    Great! Thanks. Really cool seeing all these pictures and comments.
