Projects Toymaker's Twin Engine Dragster Build
Discussion in 'The Hokey Ass Message Board' started by Toymaker, Nov 22, 2010.
  1. roseville carl
    roseville carl
    Gears sounds cool like the reverse option......
  2. Toymaker
    Toymaker
    from Fresno,CA
    The decisions been made! I decided to use a trans after spending some money on my wifes Dragster and not having much to spend on the Twin and it came together real well. I have many Ford 3 speeds and one is a Van trans with an extremely short tailshaft so I machined the Brg Retainer down to the GM bellhousing...............
    Happened to have a piece of Bronze material and made a pilot bushing that fits the larger opening of the 350 crank to have the bushing close enough for the Ford input to reach........
    And "WALA" Ford 3 speed to Chevy bellhousing in an afternoon.
    Now I have to find another T150 Trans top as I recently sold the last one I had, a rear yoke for the trans which I'll convert to a slip yoke and I can start the frame fab.
  3. 64 DODGE 440
    64 DODGE 440
    from so cal
    Nicely done Rocky...if you have a side shifter case you can just make your own top cover.:D
  4. Toymaker
    Toymaker
    from Fresno,CA
    HaHa, I should of been clearer 'bout the "top", I want to have shifter in the top like our HAMB. The poor old HA/GR is just sitting in the corner "Shakin", worrying about it's fate and what parts I may need off of it. I keep tlling it don't worry:D
  5. roseville carl
    roseville carl
    The way you're goin the ol HA/GR should be shakkin in her boots ....I'll ask around for a top for ya........
  6. Tom S. in Tn.
    Tom S. in Tn.
    Will there be any flack about cutting/welding done on the clutch can(s).
    I'd bet supper there is not a tech inspector alive who has ever seen anything that vaguely resembles this car !
    God speed; Tom S. in Tn.
  7. LOWBLAZERO1
    LOWBLAZERO1
    i believe he may have some pull, at the track. :D
  8. Toymaker
    Toymaker
    from Fresno,CA
    The Twin will only run Eagle Field (unless invited somewhere) and I know the inspectors;) My original plan of 2 3rd members and seperate bellhousings would of addressed the NHRA tech but with our Eagle Field events I have a place to play.
  9. Tom S. in Tn.
    Tom S. in Tn.
    Ok....... I'm getting it now!
    It's just hard for me to conceptualize enough people and interest to actually have your own place to race your own home made cars.
    How dangerous is earthquakes and forest fires out there? For a little bit, I'd do just like Jed and granny and I could just move there !
    BTW, after studying enlarged pics of that wire wheeled front driven car, it looks like it's powered by a 6 from a plymouth or dodge.
    Fooled me! I was so excited at first, I thought it actually had an aircraft engine!
    4 months away............ wonder how till they knew I was gone.
    Tom S.
  10. Toymaker
    Toymaker
    from Fresno,CA
    HaHaHa, You could sneak in and get home before any major earthquakes, it's the goverment that's killimg us:D The car I thinkk your referring too is our HAMB Dragster with a 170 Ford and what looks "Red Baron" model kit hedders. Majority of our participants don't race on a regular basis, their just having a good time with Hot Rods and Old Race cars that don't get out much. Tom what do you know about your Avatar? I always "Dug" the Sports Car bodied Funny Cars!
  11. Tony Lloyd
    Tony Lloyd
    Hi Toymaker..Re: Post of 1-17-11. To prevent future expense, if you purchase a candlestick, please get one with a 1 3/8" spline on the clutch end. Should the "ceramic" disc prove to be inadaquate, you will be able to go to standard twin disc sintered iron, and sintered bronze clutch surfaces, that will last for years, when you lock it up. If not, hopefully, you will be able to put stiff enough springs in the ceramic clutch hat,to handle the double torque. PLEASE DO NOT use a cast iron pressure ring! I am thinking reliability AND safety. Tony Lloyd
  12. Toymaker
    Toymaker
    from Fresno,CA
    Thanks Tony for the insight, the clutch area is a "GRENADE" in disguise and will have SFI spec parts and steel ****tersields covering them.
  13. Tony Lloyd
    Tony Lloyd
    You are welcome Toymaker.....I will meet you May 21. Tony Lloyd
  14. roseville carl
    roseville carl
    To Tom S, there is more than enough people, in fact Rocky has started a show that only gets bigger each year. Goes to show ya that there are plenty of us ol idiots who still think we are teenagers to make it happen each year. It is a notion to a by gone era when you run what you brung and had a ball doing it, anyway he has got me hooked.........................Carl
    The ground only shakes when Stormy lights em up.............
  15. Toymaker
    Toymaker
    from Fresno,CA
    The finer points and parts to put all the big pieces together are going to be the death of me:D After deciding to run the trans I went to Turners Auto Wrecking and found a slip yoke to replace the fixed yoke on the trans, with the trans and the rear end solid, the yoke being within 6" of the trans bearing I think it will be fine. With that out of the way I picked up some "Freeze Plug" for the shifter and speedo holes and had to get a seal for the combo which on all other fixed tail housings is the same EXCEPT the one I'm using........no problem for KAMAN Brg here in Fresno.
    With all of that out of the way I put her all together and ended up with a pretty short combo, now I'm waiting on a Top Loader T150 shifter for it and it will be done!
    Next I'll finish the Bellhousing, finish the engine plate and put the whole thing on the jig. Rocky
  16. 76cam
    76cam
    Sorry I'm lost here.If you pluged the shifter holes then why do you need a shifter.Maby I missed something sorry.But any way this thing is gonna be a handful....FUN FUN FUN!!!!!!!
  17. Killer
    Killer
    what an awesome build!
  18. poofus1929
    poofus1929
    from So Cal
    Awesome work on the trans.
  19. A.P. Photography
    A.P. Photography
  20. roseville carl
    roseville carl
    Way too cool Roc, no one I know has the shifter.......humm betcha could fab something that would work as you would only need one arm for 2-3 and a short stub for rev slider shouldn't be too hard to mfg.....
    Carl
  21. 65COMET
    65COMET
    76cam;it is a top-shift box now. ROY.
  22. Atwater Mike
    Atwater Mike
    Toymaker: Is that T150 shift tower a Ford truck part? Desperately seeking one also...
    for my '27 Highboy.
    Mike in A****er (60 miles North of you)
  23. 296moon
    296moon
    from england
    Nice work, cant wait for the jig work,,,,,,,,
  24. Toymaker
    Toymaker
    from Fresno,CA
    Mike, I have one coming that I found on ebay. What I do (this is the second one) is I contact a seller that is trying to sell the whole T150 trans out of a jeep (early Broncos also had them) and make them an offer of $75 + shipping for the top only, had success twice;)
  25. Tom S. in Tn.
    Tom S. in Tn.
    " To Tom S, there is more than enough people, in fact Rocky has started a show that only gets bigger each year. Goes to show ya that there are plenty of us ol idiots who still think we are teenagers to make it happen each year. It is a notion to a by gone era when you run what you brung and had a ball doing it, anyway he has got me hooked.........................Carl
    The ground only shakes when Stormy lights em up.............[/QUOTE] "
    I used to envy the west coast when I was young. Now I still do !
    I'll get there some day.
    Tom S. in Tn.
  26. Tom S. in Tn.
    Tom S. in Tn.
    " Tom what do you know about your Avatar? I always "Dug" the Sports Car bodied Funny Cars! "
    I'm sorry Toymaker, I did not catch that sentence when I posted last.
    That body was a Kellison from a car that used to run modified sports or altered, and we bought it from a guy named Jimmy Nix from here in middle Tn. It was mounted on an early vette type frame when we got it, and there where cut out shark teeth for a grille.
    We removed it, modified it and mounted it on our altered frame with a stroked FE Ford.
    All of us were young, and did not know what we were doing, and we were plagued with cracked fibergl*** like windshield pillars, so the windshield kept blowing out at speed.
    With no time to put it back in after a time trial one night at Union Hill in Nashville, we left it out.
    Mistake: the roof blew off.
    We went back to the T body the next week.
    I'd give more pics, but they are stuck in the old album they are in, and I'm afraid they will tear.
    Tom S. in Tn.
  27. I am thinking an investment in an aftermarket high strength yoke might be in order - I'd hate to think of the stock p***enger car yoke grenading right by your nuts :eek:
    I know the idea is that this thing will just smoke the tires down the track and not really strain the driveline, but **** happens :(
  28. sven1963
    sven1963
    Hey theres a jeep shifter on C/L for $60.00 in Visalia. Good luck with the build. Kenny.....................
  29. Toymaker
    Toymaker
    from Fresno,CA
    I apprciate the concern about the u-joint but I'm confident it (solid u-joint) will be OK and it will have a shield over it. I mocked up the drive ***embly for a look and now have to blow it all apart, make an alignment tool for the engine to rearend alignment then hopefully we'll be on to building a roller!
  30. Royalshifter
    Royalshifter
    Moderator
    Looking good homie!!!!
