Projects TR1Y intake
Discussion in 'The Hokey Ass Message Board' started by steamer, Apr 6, 2011.
  1. steamer
    steamer
    Anybody have a top for an Edelbrock Tunnel Ram single carb, TR1Y? I have the bottom already, thanks....:confused:
  2. CutawayAl
    CutawayAl
    from MI
    Not what you asked, but something to consider..... Although a tunnel ram can be used with a single carb, they work better with two. That being the case, you might consider two small carbs rather than one larger one. Depending on your needs, Holley makes 4-barrel carbs as small as 390 CFM. An adapter plate and two 2-barrel carbs could take you even lower/smaller if necessary.
