Hot Rods Traction Master traction bars - Nuts/Bolts
Discussion in 'The Hokey Ass Message Board' started by roadrunner_sf, Jul 7, 2024.
  1. roadrunner_sf
    roadrunner_sf
    Hi All,
    I am looking for a source for the bolts/nuts used on the original Traction Master traction bars from the mid to late 60s. Would anyone know of a source?
    The Traction Master website is up and running and I've tried calling and emailing the company but no response so far. I do understand it is a small, family run company. Would just like to get some replacements for a project where the nuts and bolts were mangled by prior owners.
    Thanks,
    SF
  2. 55blacktie
    55blacktie
    Even if you source the hardware from Traction Master, it's doubtful that it will be identical to the original hardware. A few years ago, I ordered replacement bushings from them; one of the bushings didn't fit, so I reused the best of the originals.
    loudbang and roadrunner_sf like this.
  3. bobss396
    bobss396
    I'd be shopping at Ace Hardware, they have lots of ***y quality hardware to sift through.
  4. DDDenny
    Welcome to the HAMB
    Not that it really matters but curious what these are going on and is your main objective here to retain 100% original appearance, could you post a photo of your Traction Masters?
    Many years ago I built ten sets of TM's, these were the style that had the steel angle clamped to the front of the leaf spring, on the rear I used the steel bushing/bolt/urethane bushing combination common to most hot rods, pretty sure it was a 9/16 bolt (grade eight). This leads me to recall the original set of TM's I had used a 5/8 bolt directly through a rubber bushing, is that how yours is set up.
    As far as getting hardware from the TM company, I'm guessing they just use the current cad plated grade eight bolts that are common today, thinking a person could hide the goldish color with a little bit of black paint (semi flat).
    Tickety Boo and roadrunner_sf like this.
  5. DDDenny
    roadrunner_sf likes this.
  6. loveoftiki
    loveoftiki
    from Livonia,Mi
  7. Jeff Norwell
    Jeff Norwell
    MODERATOR
    I used them with great results for both of my cars..I will say. it took a VERY long time to get my stuff(this was during Covid. but all arrived and my experience was pleasant....) Like, 6-8 months.
    You are right....... a small company today, trying to stay afloat is a very difficult thing.
  8. Dean Lowe
    Dean Lowe
    Check with McMaster/Carr. If they don't have it, it isn't made. Good people that take care of busines.
    Kelly Burns, roadrunner_sf and nochop like this.
  9. roadrunner_sf
    roadrunner_sf
    Here are some current pics of my bars and it is a '66 Mustang that was originally out in Colorado, so they took a beating. I have already painted the Bars/Brackets in black. Staying 100% original would be nice but I'm already changing some things on the car and it will never be concours. I plan to drive the car like it was meant to be enjoyed.
    I love the look of these original nut/bolts and can get the ones I have looking "decent" = no rust or paint. Car is being partly restored/repainted but when and where I can I'm reusing the original parts and pieces because the patina makes me happy.
    There is wear and tear on the nuts (one with pretty severely rounded corners) and bolts (wear in the shank and threads). I do not think the bolts are unsafe in the current condition and for what they need to do.
    Appreciate all the replies and info from the members here.
  10. roadrunner_sf
    roadrunner_sf
    I've tried to call multiple times and sent email. Will keep on trying to call for a while longer.
  11. roadrunner_sf
    roadrunner_sf
    Yes - 5/8 - 18 bolts. Mine show clear signs of wear from moving around.
    I have new poly bushing for the bars.
  12. nochop
    nochop
    from norcal
    Yup the Carr is the bomb
  13. 55blacktie
    55blacktie
    I'm very particular when it comes to details; I know what I like, even if it's not 100% original. However, it seems that the OP is going to extraordinary lengths to obtain original hardware for parts that aren't original to his car. Only the Shelbys came equipped with the bars, not regular Mustangs. He might be the only one who even notices, and it's not likely anyone will be impressed when he points them out.
    57Fury440 likes this.
  14. yellow dog
    yellow dog
    from san diego
    Traction Master had an "original" inherent flaw with the front pivot bolt in single shear.
    I experienced breakage on three different cars in the 60's before bracketing as double shear.
    "Original" might look cool, but if actual function matters a bar dragging on the ground isn't.
    Algoma56 and loudbang like this.
  15. bobss396
    bobss396
    McMaster Carr is the ticket. I wouldn't be so worried if they were not a perfect match. Likely something in at least a grade-5 and some interesting lock nuts would do it for me.
    Ace Hardware has a line of A286 stainless steel hardware, tensile strength around 135-150 ksi, some with a flange under the bolt head.
    At least the Ace by me has it. I'm not sure in a 5/8, is that 24 TPI? The fine stuff, not as great a selection, but I'd only go with fine thread,
    Tickety Boo likes this.
  16. jimmy six
    jimmy six
    I’m guessing that the correct fasteners are wanted. Since none of these had stock vehicle manufacturers #’s they are not going on a Pebble Beach restoration. I believe in shoulder bolts going thru bracket/mounts and bushings. This usually means finding a bolt that’s way longer than needed and cutting off threads. ACE for some if local and McMaster-Carr for the rest. They also have many types of locking nuts and wave or Belleville washers to keep pressure when needed…
  17. roadrunner_sf
    roadrunner_sf
    Yes, 55blacktie, and there you have it.... Shelbys originally equipped with the bars and hence my desire to keep the look. These are original to the car I'm working on. Appreciate your insights on this!
    I know it's a bit weird to want to keep some pieces original but they take liberties and change other parts/pieces/looks.
  18. roadrunner_sf
    roadrunner_sf
    Yes, I'm 100% aligned with your insights and thinking, even though I've not had a failure (yet). No question you are giving good advice and on other cars where I have installed TM bars, I did it so the fount mounting was braced and reinforced. (Had an engineer/friend provide same insights on the first set I added to a car so I didn't have to learn the hard way.)
    Using that same approach on this car is a little outside where I want to go in terms of modifications. I'll make changes that are well hidden and relatively easy to reverse.
    You have me trying to think about other approaches to improve things and keep the looks inline with the approach.
  19. roadrunner_sf
    roadrunner_sf
    Have browsed the site and have some pieces in my cart - in the event I can't reach a better solution. Still working on it, but very secure that Carr has a functional solution. Just not quite ready to abandon "the look" yet.
  20. 55blacktie
    55blacktie
    I'm not aware of any Mustang coming off a Ford ***embly line with TM bars installed. If you have a Shelby Mustang, you'll probably have better luck posting on a Shelby forum.
    Budget36 likes this.
  21. roadrunner_sf
    roadrunner_sf
    Update: I ended up getting nuts (grade 8 nylock) from Ace for now - to get the car back together. Will continue looking for an "original" look.
  22. enjenjo
    enjenjo
    from swanton oh
    . The bolts you have were made by the National Bolt company which is long out of business. They are grade three bolts.
    The nuts are Stover type lock nuts which are available from several sources.
  23. roadrunner_sf
    roadrunner_sf
    Thank you!
  24. Bruno Columban
    Bruno Columban
    Looks like Traction Masters is no longer...? Says "temporarily closed" online. No one answers emails or the phone anymore.
  25. DDDenny
    The L.A. fires might have something to do with their (temporary) closure.
  26. Tickety Boo
    Tickety Boo
    from Wisconsin
    I've seen these crimped or interference nuts at my local ACE, if you dive a little deeper, they should be there ;)
    Or you could reuse the original nuts with Loc***e if they feel loose on the new grade 8 bolt
  27. That "original bolt" image doesn't look like an original bolt to me. There's no telling when or where the bolts came from on that older setup. You know the old joke about, "You damn right it's original, except it's had 3 new bolts and 5 new nuts since then".
    You want the shank to be solid all the way through the bushing and the outside of the bracket before the threads start. You may have to make a custom-thickness washer to get it just right.
