Hot Rods Traditional brakes-Questions.
Discussion in 'The Hokey Ass Message Board' started by LUX BLUE, Jan 20, 2009.
  1. LUX BLUE
    LUX BLUE
    Alliance Vendor
    from AUSTIN,TX
    Afternoon kids.
    I am trying to figure out what the "perfect" master cylinder is for (drum roll please)
    1940 ford juice brakes-front
    9 inch rear
    master cylinder under floor.
    Now, I have asked about 100 souls today, and I have gotten the same answer....
    it is either" I have NO IDEA what the master cylinder in my car came off of."
    or
    "You want something with a 15/16th's bore or mabey a 1 inch bore..."
    which is mabey 1000 or so various master cylinders.
    I would prefer something with dual bails (two ports)
    made out of metal(no plastic resivoirs, please!)
    and with a semi deep "cup" in the back of the piston (doncha just hate it when that ****er falls out of the master cylinder and You are left screaming like a schoolgirl with 1 foor out the door! Mee too....)
    watcha runnin?
  2. SinisterCustom
    SinisterCustom
  3. blacknwhitedog
    blacknwhitedog
    from Sonoma, CA
    I've used the following on drum brake equipped cars, although it is a bail cover type, which may not lend itself well to an underfloor application. It does however use a 1" bore and have a deep enough cup to prevent the rod from falling out, a return spring on the pedal helps....
    I think Speedy Bill sells a 40 Ford style MC with a twist off cap better suited to underfloor applications.
  4. Hackerbilt
    Hackerbilt
    Agreed. (But specify that its for a drum system)
  5. fatabone
    fatabone
    We use a lot of 67 Chevy P/U truck master cylinders.
  6. LUX BLUE
    LUX BLUE
    Alliance Vendor
    from AUSTIN,TX
    see, that was actually my first choice. BUT, apparently, I have used most of those in my zip code already.
  7. LUX BLUE
    LUX BLUE
    Alliance Vendor
    from AUSTIN,TX
    I ended up with the 69 pick up master. Installed it last night-WORKS *****IN!
    I also ordered the 67 Mustang at the same time. same bore size, but had the pedal rod attached- which was a no0go for my application (already had a good set up there.)
    good pedal, great resonse.
    Thanks Fellas!
    Owe Ya a beer!
  8. continentaljohn
    continentaljohn
    I like the early Broncos 1968-1972 and all have the 9" rear to start with along with drum brakes with 15/16 wheel cylinder.
    If you want to get fancy go with the 1972-75 jeep were they also have the 1" cylinders for drums all the way around but also have a place on the Master for a brake pressure switch. Also they face into the frame rails if that matters.
  9. The deep cup is for manual brake systems, the shallow cup is for power systems.
