Technical tranny cooling lines
Discussion in 'The Hokey Ass Message Board' started by trollst, Feb 21, 2016.
  1. trollst
    trollst
    Got a 2.3 pinto with a C3 behind it in my 27 roadster, test driving it yesterday, after around a couple miles or so, one of the lines blew partially off right at the cooler on one of my custom made lines. Of course, it's right behind the grille shell well out of reach and a tear down is necessary, oil everywhere, huge wipedown gonna happen today. Anyway, this has never happened to me in many years of building, lines are made with a partial flare, proper transmission hose used, the proper size, really a surprise to me. How much pressure do these lines carry? I thought it was around fifteen pounds or so, but now I'm not so sure. The pressure line to the cooler enters the bottom of the cooler and the return leaves the top, mounted in front of the rad on it's side, three row hayden cooler. Pics won't help, it's stuffed in behind a custom grille shell, you can barely see it never mind take pics.
  2. Model T1
    Model T1
    I've always done a single flair on the metal line and slipped it in the rubber hose a few inches. Then a hose clamp right behnd the flair and another near the end of the metal line. Been doing it this way since the 60's. with no porblems.
    Maybe your clamp just wasn't tight.
  3. trollst
    trollst
    Loose clamp, how much pressure is in these lines?
  4. mgtstumpy
    mgtstumpy
  5. I may be wrong, but I think that TCI chart is line pressure. Which isn't cooler line pressure.
    I've always thought cooler lines had around 20 psi but I am not sure where I got that idea.
  6. mgtstumpy
    mgtstumpy
    I think you might be right, I'll retract that earlier statement :D:oops:
  7. paul55
    paul55
    from michigan
    Make sure to use this. Handles the pressure and higher temps. Double clamp! images (6).jpg
    Model T1 likes this.
  8. Mr48chev
    By "partial" flare I am ***uming that you used the die in the double flare tool to make a bulb at the end of the tube to slip a hose over. I've never had a problem with that as long as I used the proper type and size of hose for the fluid I was working with.
    I'd have to ask if the hose and end were different sizes, if the clamp was not tight or tight but not in the right spot or if it wasn't the correct hose for trans fluid.
  9. trollst
    trollst
    No.... my stupidity, as usual, yes that's how the steel line is made, but in my haste to get it running, (I'll get that later), I didn't push the hose onto the steel line far enough, or tighten the clamp enough. Of course, never thought to recheck it. Proper hose, proper lines, just the dummy at the controls, I was just blown away by the amount of oil it pumped out over the course of a city block, trying to get it back to the shop, which I did. Even though it was a partial leak, it's blown oil all over the engine and inside the hood and side panels, made quite the mess. That's why I'm curious what kind of pressure the cooling lines run, anyone know?
  10. brokenspoke
    brokenspoke
    DO NOT USE FUEL LINE
  11. Crosley
    Crosley
    from Aridzona
    Most Ford 3 speed trans run 20 - 45 psi in the cooler system. Please be careful with cooler lines. They often run near , over , around the exhaust system. Trans oil can flash over to a fire from exhaust tube temps
  12. trollst
    trollst
    Thanks for the info.
  13. dfriend
    dfriend
    from B.C.canada
    Cooler line pressure is convertor out pressure. when it returns from the cooler and enters the transmission it becomes lube pressure. Condition of convertor may change that pressure, and failure of lube pressure regulator also. Install pressure guage and read lube pressure. Lube pressure varies from trans to trans.
  14. Bandit Billy
    Bandit Billy
    I don't always use clamps,
    but when I do... they
    are for fuel injection.
  15. butch27
    butch27
    I also use a short piece of hose at the radiator connection.
  16. Dino 64
    Dino 64
    from Virginia
    Please educate me. Why not?
  17. Model T1
    Model T1
    Thanks. You found the problem and p***ed it on!;)
  18. brokenspoke
    brokenspoke
    Transmission fluid brakes down the rubber in fuel lines
  19. Inked Monkey
    Inked Monkey
    Interesting, I've always just run fuel line. Is this something that I should switch out?
  20. Dino 64
    Dino 64
    from Virginia
    Thanks, I thought you were talking about steel line. No rubber not good, made that mess already!
  21. I would switch it out. I've seen others use fuel line and it comes apart after some time.
  22. Inked Monkey
    Inked Monkey
    Cool, the next question is, Will the parts store peeps know what I'm talking about?
  23. Dino 64
    Dino 64
    from Virginia
    Just get steel brake line in the correct diameter and bend away. Put double flares and fittings just like brake lines.
