Tranny fluid on bare metal?
Discussion in 'The Hokey Ass Message Board' started by vintage44, Feb 19, 2010.
  1. vintage44
    vintage44
    from NY
    1. New York H.A.M.B.ers
    Caught a few minutes of 'Two Guys Garage' the other day where they chopped a sedan. The car was already in bare metal when this was done but near the end of the show one of the guys dumped tranny fluid on a rag and wiped down the body. :eek: He said it would keep the bare metal shiney and stop rust. :confused: Did I hear all this correctly? I've seen any number of methods to prevent rust on bare metal here on the HAMB but not sure I've ever heard of this one.
  2. GREASEMONKEY72
    GREASEMONKEY72
  3. blt2go
    blt2go
    it should prevent rust, but i know of many better ways to accomplish that. oil works on my guns and shovels but that is it.
  4. GassersGarage
    GassersGarage
    Works. It's easier to take off when you're ready to paint.
  5. 49ratfink
    49ratfink
    what happens when you miss some while cleaning it off and it causes the paint to lift later.
    sounds like a lame idea to me, but it must be OK cuz it was seen on TV
  6. kustom66cat
    kustom66cat
    If you don't plan on painting a car thats probably ok but if you plan on paint, you should use a sealer epoxy on it as soon as the parts are stripped so you know its right.
  7. Mr48chev
    Anything that you put on bare metal will have to be cleaned off when you go to the next step in body work or go to paint it but their theory may be that trans fluid is easier to clean off and contains less things that might contaminate the metal than WD-40 or some other stuff.
    I don't get the fascination with running bare metal as a finish. I can see pulling the rig out of the shop when the body work is done to perfection and taking it to one show or run in bare metal to show the world your workmanship before heading back to the shop with it and doing the prep work for paint. That's cool, what I don't see as cool is showing up two years later with the same bare metal and your case of WD40 and Scotch Brite pads with a car you haven't hit a lick on for the past two years.
  8. Flatheadguy
    Flatheadguy
    Amen, Brother!!
  9. 4tl8ford
    4tl8ford
    from Erie, Pa
  10. Rich Wright
    Rich Wright
    Put a small amount of trans fluid on your bench and leave it undisturbed overnight... You might be amazed at how far it has crept by the next morning.
    It will creep around till it finds every seem, crevice, or any other spot there is. it will creep in between panels and along the underside of the sheet metal.
    If your not planning on painting your car...ever, then this may be the way to go. Otherwise, it's a step backwards.
  11. OHEKK
    OHEKK
    My metal finisher uses anti freeze!
    He claims it is full of anti-oxidents and corrosion inhibitors.
    and it easily washes off.
  12. An epoxy primer is best for the fresh bare metal. Just a light coat is sufficent and down the road when you are ready for body work just a fast freshen up and you can do bondo right over top.
    kgdb
  13. Steve-Cook
    Steve-Cook
    from Garner, NC
    There is too many commercials during that show
  14. dalesnyder
    dalesnyder
  15. 58custom
    58custom
  16. budrow
    budrow
    Oh, that Pam
