Tranny guys, TH-400 question
Discussion in 'The Hokey Ass Message Board' started by Roothawg, Aug 13, 2006.
  1. Roothawg
    Roothawg
    I have a buddy with a TH-400 with a problem. The ****** is a manual valve body, reverse shift pattern behind a blown 454 Chevy.
    The problem is the ****** won't move in reverse after it gets hot. You can drive it about 20 minutes and you lose reverse totally. When it's cold it hooks up like it's supposed to.
    Any ideas?
    Thanks
    Root
  2. lesabre59
    lesabre59
    I had a similar problem, I would run for just a short time and would lose all gears, forward and reverse. I figured it was getting too hot, possible turning the ****** fluid to foam because as soon as it cooled down it was fine. I added an external ****** cooler and have never had the problem again.
  3. Crosley
    Crosley
    from Aridzona
    If you do not have a problem in 3rd gear when the ****** is HOT, then the problem is the low/reverse band.
    A pressure loss there, bad or hard seal or the trans is too hot.
    Does the car have a high stall RPM converter?
  4. Roothawg
    Roothawg
    3000 stall , has external cooler. ****** is 4 years old. 3rd gear is ok.
  5. Any chance it's as simple as low fluid?
    Some automatics are supposed to have the fluid level checked while in drive from what my trans shop owning friend told me a while back.
    He was speaking specifically of my 67 Barracuda trans behind a power pack 273.
    Added a quart and it cured the problem of slipping in low.
  6. Roothawg
    Roothawg
    I don't think it's that easy. It would be nice though.
    He has checked all the obvious stuff I think, but I'll ask him anyway.
  7. Crosley
    Crosley
    from Aridzona
    :D If 3rd gear is good....
    then it could be a shifter out of whack( adjustment) , low/reverse band servo leak , pin too short , cracked servo piston , blown out gasket , crack in the case at the servo.
    so many things
  8. Roothawg
    Roothawg
    So the chances are that we are gonna have to pull the ******. Dang....
  9. squirrel
    that's generally the way it is with automatics...if there's fluid it in it, and it slips, out it comes!
  10. Crosley
    Crosley
    from Aridzona
    I'd pull the pan , valve body and rear servo to check for troubles first.
    Sometimes the servo piston cracks in the groove area that the sealing O ring sits in.
    then pull the ****** out if all is OK in the pan.
  11. keith089
    keith089
    What would it be if he was loosing third? I have that
  12. Roothawg
    Roothawg
    It's not slipping. It doesn't do anything.
  13. squirrel
    "not doing anything" is slipping, real bad.
  14. Roothawg
    Roothawg
    I'm figuring it has to be a pressure issue somewhere.
  15. squirrel
    I scanned a pressure schematic of the th400 in reverse, so you can see where to look for problems
  16. Roothawg
    Roothawg
    Cool man THANKS!
  17. tonydamnread
    tonydamnread
    from Nashville
    i'm having a similar problem with the 350 in my truck and it ended up being something wrong with the shifter shaft mushrooming out of place making it leak fluid. i'm not good with transmissions so i let a mechanic i know check it out and that's what he said.
