Tranny help...
Discussion in 'The Hokey Ass Message Board' started by txgreaser, Nov 6, 2005.
  1. txgreaser
    txgreaser
    I just picked up a 61' Ford Galaxie with a 292 wide block and three on the tree. I wanted to switch it out with an automatic tranmission. what will be a good tranmission without having to cut the floor to make the tunnel bigger. I was thinking of an AOD from a mustang but I didn't know if that would work. Let me know guys, thanks....
  2. squirrel
    If you're gonna keep the Y block, then you'll need a trans that will bolt up to it, which limits you pretty much to the old Cruisomatic.
    Unless you want to pay $$$ for an adapter.
  3. txgreaser
    txgreaser
    How much do these adapters run?
  4. squirrel
  5. txgreaser
    txgreaser
    Thanks squirrel, this helps alot.
  6. Deyomatic
    Deyomatic
    from CT
    Someone in the cl***ifieds section is selling a bunch of adaptors...do a search, it may have been cougardan, but I can't say for sure.
  7. squirrel
    those are for manual transmissions...
