Technical tranny question
Discussion in 'Traditional Hot Rods' started by Ron Brown, Feb 18, 2016.
  1. Ron Brown
    Ron Brown
    Fixin to go swap meeting soon to look for a ******...question is...is there a sure fire way to tell a 39 ****** from all the earlier years...they all look similar on the outside Ron
  2. barrnone50
    barrnone50
    from texas
    Look to the left back bottom casting number 78 is there. There are other things to look for. The Tardell book is helpful.
  3. FritzJr
    FritzJr
    Look for the double detents on the shifter housing. However, you still need to take the shifter off to look at the forks to make sure it has the larger fork and later style synchros.
  4. 56don
    56don
    I wish you guys would stop calling them "******s". That means something else entirely in todays society..:eek:
    falcongeorge and 3wLarry like this.
  5. nwbhotrod
    nwbhotrod
    from wash state
    pre op or post op
  6. Clik
    Clik
    The new ones have a different shift pattern, and a distinctive whine if you don't lube them properly.
  7. gimpyshotrods
    gimpyshotrods
    If you have to ask....:rolleyes:
  8. BuckeyeBuicks
    BuckeyeBuicks
    from ohio
    Please don't tell us how you know this !!
  9. 1946caddy
    1946caddy
    from washington
    Bruce or Caitland
  10. Ron Brown
    Ron Brown
    Funny...I actually thought that when I posed the question, but I figured you all are so damned old you wouldnt catch it.
    36 ROKIT and 56don like this.
  11. gimpyshotrods
    gimpyshotrods
    46, and I live in San Francisco.
  12. Ron Brown
    Ron Brown
    46!?!?!?! yer still a kid.
  13. gimpyshotrods
    gimpyshotrods
    Sure am!
  14. ronzmtrwrx
    ronzmtrwrx
    Check out van pelts website. Lots of info there.
    warbird1 likes this.
  15. yruhot
    yruhot
    Well at least you know they are age appropriate for this site.lol.
  16. Ford used the "78" beginning in 1937.
    Charlie Stephens
  17. I second this suggestion, go to http://www.vanpeltsales.com/FH_web/flathead_home.htm . You really need to identify the gears/shifter as they were all pretty much interchangeable (as sets).
    Charlie Stephens
  18. Mac VP
    Mac VP
    Use this link to the Transmission Identification info on our website
    http://www.vanpeltsales.com/FH_web/flathead_transID_3speed.htm
    Read all sections and print out pics to save. Remember when looking at swap meet trannies that guys have mixed up the ge****ts over the years. Take a ratchet and 1/2" socket. If the top isn't already loose for inspection, ask the seller if you can remove it to check out the ge****t. Plenty of things to watch for, but there are many things you really won't be able to see properly also.
    Even if the ge****t is toast, the case, tower, shifter lever, etc will have value. Make your offers accordingly.
    warbird1 and ronzmtrwrx like this.
  19. barrnone50
    barrnone50
    from texas
    Sorry should have been more clear. The desirable case is what I should have said..
  20. Deuced Up!
    Deuced Up!
    LMAO!
  21. aaggie
    aaggie
    I think I have a few neckties older than 46.
  22. Chucky
    Chucky
  23. verde742
    verde742
    the way I can tell, 39 Ford. the tower that holds shifter is vertical all the way around, earlier towers have a angle on the engine side.;)
    :eek:Like ****, I can't describe it very well, but I know it when I see it:rolleyes:
  24. Bruce Lancaster
    Bruce Lancaster
  25. Ron Brown
    Ron Brown
    Man...I always ***umed you guys were sick........this just confirms it.
  26. Bruce Lancaster
    Bruce Lancaster
    Well, there are important issues here; some of the hormones involved in turning a '39 box into a ****** can make the gear teeth brittle. You just can't be too careful when doing something radical like this!!
  27. falcongeorge
    falcongeorge
    from BC
    :eek::eek::eek: There are times when I really LOVE this place...
  28. DDDenny
    A mind is a terrible thing to waste!
    falcongeorge likes this.
  29. 1946caddy
    1946caddy
    from washington
    He wants a 39, sorry.
    Tomincanada and Chucky like this.
  30. gimpyshotrods
    gimpyshotrods
    Bummer. I'm a lot of fun!
