Tranny Swap
Discussion in 'Questions & Suggestions' started by welditall, Nov 27, 2003.
  1. welditall
    welditall
    from Covina ,Ca
    I have a 1963 SS Impala with a 283 v8. i do not like the original ******, so i was thinking of buying a another one. A buddy mention he has a ****** from a 1974 monte carlo. We measured it and it is the same length as the impalas ******. What will it take to completely do a ****** swap of this sort?
    id appreciate the help.
  2. kyle paul
    kyle paul
    from sac
    a man the olny i can think u will need is a crossmember for the ****** but if only if it dont bolt up the same if the ****** mounts in your car is a powerslide you ll need a new kickdown also what kinda ****** do u have and what areu putting in let us no we can give u a little more help that way and also maybe a shifter but need to no what the two ******s are kyle
  3. welditall
    welditall
    from Covina ,Ca
    the original is a powerglide and the 1974 ****** is a turbo 350. i wanna put the 1974 ****** in the 1963 Impala and get rid of the Powerglide.
  4. Ayers Garage
    Ayers Garage
    [ QUOTE ]
    [/ QUOTE ]
    What did he say? [​IMG]
  5. done it in my girls '61 bel air, will bolt right in (block, crossmember and yoke). you need to take ALL the stuff from the monte carlo, kick down cable dipstick tube (notch the firewall pinch weld a little), trans mount. you will need to modify the original shift arm and bracket to work on the th350, also you need to grind shift arm (above) to get into low (and have the indicator right). MAKE SURE the yoke on the driveshaft has a closed end (NO hole by the u joint) or the trans fluid will leak out. you will also have to rework the cooler lines.
  6. Mike Paul
    Mike Paul
    How much for the powerglide????
  7. welditall
    welditall
    from Covina ,Ca
    ill let you know when im ready to sell the powerglide.
  8. welditall
    welditall
    from Covina ,Ca
    anyone one else do this type of swap?
