Trans Adapter For 8-BA Flathead
Discussion in 'The Hokey Ass Message Board' started by flathead4d, Oct 24, 2007.
  1. flathead4d
    flathead4d
    OK. Who makes a trans adapter to mate a Ford T-5 trans to a 8-BA flathead? NOT a GM-T-5 trans. Also, what's with that rear mount being on an angle? How did you work around that? Just make a wedge shaped piece?
  2. banjorear
    banjorear
    M.E.C.- I think they are in Ohio. I'll try to get their information.
  3. tjm73
    tjm73
  4. tommy
    tommy
  5. tjm73
    tjm73
    Sweet! Mustang T5's are common as dirt. And have decent ratios.
  6. Flat Ernie
    Flat Ernie
    Tech Editor
    Tommy - does that work with late-model Mustang T5 or is that the '65-8? Ford bolt pattern? Looks like the latter (like a Toploader would bolt to it)...
    I seem to recall av8 using one of those & then the little adapter plate between it & the Mustang T5 he used.
    To the original question, you mention you have an angled mount which I'm ***uming is the trans mount pad on the tailshaft. Does this mean you're using a '93-up Camaro/Firebird T5??
    Yes, you can fabricate a wedge-shaped adapter if you retain that tailhousing.
    Besides the tech piece I did, there's lots more info (including Ford T5 to 8BA steel bellhousing) here:
    http://www.jalopyjournal.com/forum/showthread.php?t=169265
  7. flathead4d
    flathead4d
    Yes, it's a 93 Mustang trans and I want to hook it up to the Merc cast iron bell housing with the cross shaft style throwout bearing fork. Thanks for your replies.
  8. tommy
    tommy
  9. Flat Ernie
    Flat Ernie
    Tech Editor
    Then your trans mounting pad shouldn't be angled. The only angled mounting pads are on ******s originally used in F-body (Camaro/Firebird)...unless your tailshaft has been swapped...
