Trans dust cover question ? ?
Discussion in 'The Hokey Ass Message Board' started by Deuce Roadster, Jul 29, 2004.
  1. Deuce Roadster
    Deuce Roadster
    I have a Turbo 400 in the roadster. I am using a 153T flywheel and a small torque converter. The 32 sits low....... I keep beating up the stock dust cover (3 in 9 years). I know that some Turbo 350 dust covers will fit a Turbo 400.I have heard that some GM (Vega/Monza maybe) type cars with a Turbo 350 came with a smaller diameter dust cover (small converter and low to the ground ...GM made the covers different).....Is this true?
    <font color="red"> OR I am open to any suggestions on a workable cover. Redrilled 700R4 cover or whatever. I need about 1 inch more clearance. </font>
    Thanks....Deuce Roadster
  2. BELLM
    BELLM
    How much clearance do you have between the flywheel &amp; the bottom of the cover? Can you cut bottom of cover out &amp; section the cover enough to get the 1" without intereference with the flywheel?
  3. Deuce Roadster
    Deuce Roadster
    I have about 1 and 1/2 inch clearance between the cover and the flywheel/converter. The dust cover on it now is mashed in almost 1 inch.
    I was hoping that a Vega or something would work........I am a far better parts hunter than fabricator.......plus it's easier [​IMG] [​IMG]
    I may have to cut a cover and FAB something if I cannot find one that will work.
  4. Hot Rod To Hell
    Hot Rod To Hell
    from Flint MI
    What would happen if you just left the cover off?
  5. willowbilly3
    willowbilly3
    from Sturgis
    You might try one of those heavy cast aluminum ones off a 4x4. They have a couple ugly mounting bosses from the reinforcing braces but you could grind them down and polish it up to look good.
  6. I never put mine on and it isn't even dusty
  7. Jeff Norwell
    Jeff Norwell
    MODERATOR
    I left mine off on my 34...the crappy oem plastic one cracked,dirty and ugly ant the shitty MR.GASKET/tiawan chrome crap never fit properly..
    I never had a problem.
  8. Dirty2
    Dirty2
    The 4X4 will work as long as its a 400 the next thing you need to do is make some sort of a skid plate because the next thing you bend is the fly wheel...
  9. exactly - the chrome one I bought didn't fit for shit and every time I get under there - it looks clean - so I think I have decided to for go it all together - I like being able to check the flex plate bolts quick
  10. Hot Rod To Hell
    Hot Rod To Hell
    from Flint MI
    Good! I have never run them on any of my hot rods, but I was just testing the waters to see if you guys had some big reason that I should! [​IMG]
  11. Bruce Lancaster
    Bruce Lancaster
    Car Craft addressed the technical issues of running without a dust cover years ago, thoroughly and comprehensively:
    "Who ever heard of dust on a racecar torque converter?"
    The thought of snagging the flexplate on the ground is pretty chilling, but if the car bottoms to that level I don't think the dust cover is any actual protection--it's not nearly strong enough to resist downward movement of car or impact with solid anything at road speeds.
  12. Iceberg
    Iceberg
    My OEM cheep plastic cover will not provide much protection from anything but dust &amp; grim.
  13. DrJ
    DrJ
    The Vega cover has HOLES IN IT to let air and DUST circulate through and out the holes in the bellhousing because the trans is cooled by air circulation past the torque converter....
    SO is dust realy an issue, or is that just what the thing is called?
    People toss the primary covers off of Harleys don't they?
    I don't have a cover on mine either, I figure it's one more source of trans cooling.
    I just have to hope no one (or thing) crawls under there with the engine running... [​IMG]
  14. oh - and who knows what size those wormy little bolts are that hold the thing on anyways? I always have to go dig some metric crap socket out
  15. Deuce Roadster
    Deuce Roadster
    I am paranoid.............
    I had a large sort of rock get into my clutch/flywheel on my 55 Chevrolet years ago. NO dust cover. Broke up some expensive pieces (not really much $$$ but I was broke at the time ...teenager) Had to walk for 2 or 3 weeks.
    I have 3 different dust covers that will work and have found 1/2 of a inch difference in them. I just hoped that with ALL the LOW vehicles on the HAMB .............that someone had a solution.............better than what I could come up with.
  16. Crosley
    Crosley
    from Aridzona
    [ QUOTE ]
    [/ QUOTE ]
    ============== leave the cover off
  17. primered54
    primered54
    I've had mine off for years now... no issues! Most of the really low cars I've seen aren't running 'em either. I agree that I like to be able to look at my flexplate and bolts while underneath without having to pull a flimsy piece of metal off.
