I have a factory gm mount in the crossmember for my model A that fits the saginaw. Does anyone know if a power glide has the same mounting location as the saginaw. sorry cant find the picture of it
I get 20.5" from the back of the engine block, to the center of the mount bolt holes, on a Saginaw 3 speed, Saginaw 4 speed (both with a V8 aluminum bellhousing), an aluminum PG, and a TH350.
Sorry guys i should be more specific. Its a 4 speed saginaw that bolts right up to the mount. Will a mid sixties powerglide bolt in the same mount sizewise and location or will i have to change my mount? Would it be a direct swap?
What I said above is that it should bolt right in....sorry for the confusion. It wouldn't hurt to measure things first to make sure. There were some changes to PG transmissions in the mid 60s.
Ok thanks i was wanting to go automatic since it might have to be my daily for awhile. Hoping it won't be too much of a headache. thanks squirrel
